Upgrades for the Tracker Its pretty much done. 4-7-10
Started by Crazymays77, November 23, 2009, 02:10:25 PM
Mudduck
Mudduck
==hstrap
Crazymays77
well i worked on the motor this morning then was working on putting the tcase in and found out its broke. gonna have to get another one. oh well no biggie.
redneck renegade
Quote from: The Original CrazyMays77 on March 19, 2010, 05:33:13 PM
li got 1 off a 98 blazer its auto shift ur prolly lookin manual?
Crazymays77
yeah pass drop 208. the guy i bought it from is gonna swap it for another one he has. no biggie.
Crazymays77
the new motor is all together except the intake carb and dist. then the acc. but those are not going on till its in the tracker. got the mock motor where i want it and everything looks good. need to make a crossmember but i have to work around the front drive shaft so have to figure that out yet. then i found that my upper brackets for the rear links are bent to crap so i have to re do them after i get the mock motor out. looks like i got some work to do  lol.....
Crazymays77
well i went and got a carb, dist and some odds and ends from mudbrat71. thanks man.
Crazymays77
well i got everything made for the motor trans and tcase to get put in now. I made the crossmember and finished the motor mounts and pulled the old motor and welded everything solid. then painted everything. here are a few pics of the motor and the engine bay.
redneck renegade
are you gonna have to get a oil filter relocator or does it fit ?
Crazymays77
not sure on that yet. there looks to be enough room gonna find out soon thats for sure lol
SageJp
Looks like it'll be a fun toy! Nice work.
Crazymays77
Well the new motor is in and got most the acc. on the motor. just need to find a way to bypass the a.c compressor and the smog pump. here is a couple pics i took with the camera phone so not sure how well they will turn out.
eldestructo
Looks Great! Keep up the good work Cory  GotMud?
Crazymays77
well i got the tcase swapped out for a good one today got the good one in too. i got the elec fuel pump and ordered some parts for the motor acc. I got the radiator mounts in just need to make the upper ones to hold it down just havent figured out how i want to do that part yet. now i need to get a throttle cable that will hook to the carb and my gas pedal. then i need to make a bracket for the shifter cable to work. then on to wiring it all up. lots to do yet.
Towstrap
Towstrap
www.gotmud4x4.com
If your not getting stuck, your not having fun.
Axlejack
lookin good thats like goin from a sbc to a bbc loll
dirtydog
looking good make a little more in there and u can drop in a sbv8 ;D ;D ++peace
redneck renegade
Quote from: The Original CrazyMays77 on March 20, 2010, 10:04:20 PM
advance in clio had the ac bypass pully in stock for my ford i bet they got urs
Crazymays77
yeah i ended up just leaving the a/c on it the bypass that i got wasnt the right one and that was the only one they showed for my motor so screw it i will just leave the a/c on it. got some of the wiring done today. just need to get some toggle switches for the acc.
