89 s10 piece together
Started by camok10, December 03, 2009, 02:03:43 AM
camok10
well my neighbor gave me a 89 gmc jimmy 4.3, 5spd 4x4 2dr so im going to try and piece toether bothe the box style ones i have now and make a good one.
for now plans include- fixing the front end so it's not locked up and wheel it
down the road- sas, tbi 20k mile jasper 350 which he also said if going in this i could have, and wheel the crap outa it and if im lucky maybe even start another one and put the 4dr body on my k5 frame i think im going to stick with the tbi 4.3 but run a th350/208or205 or maybe a 700r4/208 and for axles im thinking 3/4 chevy axles or if i keep the 5spd maybe a ford 44 and 9"
84 c10 project
82 c10 beater diesel
camok10
#1
would any one be interested in tradeing the 5spd and 231 t case outa this  or my k5 frame for some 3/4 ton chevy axles with spring's or a th350/208 combo with kick down cable. or maybe the k5 frame for some ford axles and front suspension set up out of a 1/2 ton?
84 c10 project
camok10
here are some better pic's
84 c10 project
camok10
so i think im going to try and run the radius arm set up......... now the prosces of geting part's on the cheap loll
84 c10 project
good luck
Quote from: camok10 on December 06, 2009, 01:27:24 PM
Bo Duke
Whats wrong with the front end? How did it lock up? Brakes rust up or the ring and pinion mess up?
camok10
umm it was getting beat hard and stoped so im guessing internal failure it was also around the time the motor started knocking hard core i belive shortly after to be percise loll
84 c10 project
loll Sounds like you've got your work cut out for you bub!
camok10
ya.......... if i ever get enough free time im going to pull the 4.3 and front diff out of that green one and  and make this move till i get around to the sas then the green one's tran's is going to go in that step side........ wow i have to many projects not enough time and no money loll
84 c10 project
