my new project (pitbull) now with pics
Started by ballistics-10, May 06, 2010, 10:28:04 PM
ballistics-10
I went out a got a 1995 mustang. Black with black leather. It also has a sbc 355 in it with a tci 400 trans. The motor is pushing 450 at the wheels. But I want a little more. So I will be getting dart or afr heads with a bigger cam and 100 shot of nos..(Maybe).. Pics will be up soon.
middleroadBOB
sounds cool, but why dont you just put your bbc in it?
lets see some pics
ballistics-10
Because that bbc is to much for the car and I would just break p00 all the time..
So, this is what you have going on now.
applaudd
ballistics-10
yep.. yea my plate that i should be getting in a week or so is 355snke..
2trackr
here are a few pics of the stang
i have a video to post too, but i cant host it with imageshack, if i can figure it out ill get it posted up
2trackr
here is the video of mikes burnout at boomers car night
ballistics-10
Having a problem with keeping a battery in the car.. it has a underdrive pulley set.. And the alt only charges at 2400 rpm or higher. It is fine during the day but when it is night and I have to turn the headlights on it instantly kills the battery and it won't charger good enough and has to be jumper everytime.. Now can I keep the underdrive pulley on the alt and get a higher amp alt or do I have to switch the pulley back to stock?
yoiu put ur bbc in there it will make that thing look like a pretzel
ive never ran the underdrive pulleys....i run stock...i would say just put a stock one back on to keep it from getting jumped all the time....sweet ride tho man..def going to have to cruise together this year!!!!
ballistics-10
Yea hit me up when the dream cruise..or anytime before..
ballistics-10
Ok found another problem the car doesn't have a pcv and it built up to much preassure inside the motor and blew the front crank seal forword a little and it now leaking oil.. And the little breather on the valve cover it blowing oil out of it..
ballistics-10
Ok update.. I put a pcv valve in the motor and now it is blowing oil out the beathers anymore.. But because it didn't have one it built up to much pressure and has blown out some seals.. So I will be replacing them..I added another trans cooler because my trans was hitting 250+ so it now has 2 trans coolers. Now on to the good stuff.. I ordered a new cam.. 60104 lunati voodoo cam. .504/.525 lift lobe separation 110 degrees. Duration 276/284.. 2200-6400rpm.. Buying procomp anti-pump up valve lifters..which will give me extra 500-1000 rpm over normal lifter..
I would put your stock pulley on...I was never a fan of under drives, the factory made them a certain size for a reason. post a pic of that SBC under the hood...I would like to see how much more room there is compared to the wide 4.6 modular.
