poorboyzmuddin project truck
Started by poorboyzmuddin, January 11, 2011, 02:12:38 PM
poorboyzmuddin
its a 1990 Chevy s10 extended cab has a 3inch body lift and a 7 inch suspension lift..... when i got the truck it still had the independent front end in it so my father and i tour that out and started to put in a solid axle called around every where for a conversion kit no one made one as they told me so we had to do the hole front end by hand first time for the both of us.... as the truck sits right now it still need the drive shafts put in the 44inch boggers put on and the linkage hooked up for the trans and t-case and then every thing welded...... i also want to diamond plate everything inside of the truck for an easy clean but that will be later down the road.... i have no name for the truck not sure what to call it i guess ill have to wait and see how it does in a hole to give it an name....
IT IS WHAT IT IS.......
poorboyzmuddin
i have a question for you guy's what is a good way to run my radiator from the bed of  my truck ?
what motor are you going to use to spin them 44 boggers?
I have pics in my project page with my line run to the box on my bogger. check it out!
poorboyzmuddin
its a hyped up 305 but i have a 350 in the works right now just going to play with the 305 till it blows or something
poorboyzmuddin
OK will do betterbeaters thanks
what gears are you running cause the 305 wont like 44 boggers
poorboyzmuddin
i got a set of axles for free form a buddy of mine i think they are Dana 70's but don't hold me to it so im not sure on what the gear ratio is to tell you the truth this weekend when i get to my truck i will take some pic of the axles and post them up here im not that good about that kinda stuff i just help put the truck together and fix it when it breaks not that great of a mechanic but im learning :)
poorboyzmuddin
what size hose did you use on your radiator from running it from back to front?
Us muffler pipe for the long straight runs and get some used radiator hoses for the bends. That's what I did and it worked good.
poorboyzmuddin
I used 1.5 and 2" pipe for my lines and 2" was way to big still wish I had made it smaller!
i used 1.5 still was overkill
Quote from: MR NASTY on January 11, 2011, 08:46:06 PM
good to know my buddy used 1" and 11/4 and it works very good!
why, to much water, to heavy? or stays to cool?
i used rubber radiator hose works perfect
to much  to push  ended up putting in a deal to restrict it to get the water moving
poorboyzmuddin
here is an update on my project for you guy's as of right now i have the truck drivable steering is almost done 44s are on breaks are hooked up all i need to do is hook up 4x4 hook up the hydrological steering do a little bit more welding and hit the first hole ill get some pic up asap
poorboyzmuddin
all most done
mudboggTshirts
WOOT WOOT! I like it! SHARP! ;D
