Ford Question..need help...?
Started by Bender, January 13, 2011, 05:56:48 AM
Bender
I have a 95 Bronco w/ a 5.8L (automatic). I pulled that motor and put it in a 92 F150 5 speed. It all fit and bolted. But now it seems like it has a delay on the throttle response. It idles erratically. Any ideas folks..?
rangerwheelinmike
have had that happin to me with my 5.8 probley a vacuum leak theres so many vacuum lines on them its had for them not to leak everything is vacuum on them
Bender
I thought about that. But could it be a sensor also..? Cause I  pulled the 5.8L from an automatic and put it in a 5 speed..? And I switched out the computers too...
rangerwheelinmike
thats what i was guna ask is the check engine  light on?
Bender
the bulbs in my dash maybe burned or my fuses....have to check them tomorrow....
rangerwheelinmike
idk theres so many thing it could be on that truck you if it was a 95 it could have been obd2 and the 92 is obd 1 so could be a problem im not sure though
rangerwheelinmike
#6
could be timeing to
jtech
How does it run otherwise ? I'd check timing for sure... I'm not sure if you know this or not but there is a 2 wire plug on the fenderwell that you have to unplug when setting timing otherwise it won't work correctly.
Bender
I'm checking that this morning. Thx folks
Bender
Ok...here's an update. I found a couple vacuum leaks and plugged them. Now it idles fine. But now, when I hit the throttle, it bogs down and wants to die. Like there is a fuel problem. I'm going to change my injectors and plugs cause it was sitting outside (covered under a tarp) for almost a year. Thx for all the help.
rangerwheelinmike
i have to look i might still have some parts for that not sure though
Broncoholic
Quote from: Bender on January 14, 2011, 02:41:12 AM
Check fuel pressure & clean the throttle body, kick the timing up 3 deg. Prolly timing chain needs replaced.
remove the dist cap turn the crank both ways & see what lag you have in the rotor
Should have installed a steel tchain while it was out of the truck.
fordboy19
Broncoholic
Broncoholic
Bender
I did change the idle position sensor...it's alittle better but still hesitates when you hit the gas. I going to change the fuel filter soon...thx for all the help.
Broncoholic
Quote from: Bender on February 04, 2011, 07:54:29 PM
Throttle Body is dirty get some throttle body cleaner
Here is a link
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDQQFjAD&url=http%3A%2F%2Fwww.spikapino.com%2F%3Fp%3D119&rct=j&q=throttle%20body%20cleaning%20ford&ei=0GdMTcizJNKRgQeX1Pwr&usg=AFQjCNFc6PiHwjy3zFkgCwKYvCB7_EsvKg&cad=rja
89SHORTBOX
Just a question.. Kinda realated but did u put a pilot bearin in the end of the crank shaft?? I no that gas nothing to do wit the engine not running right but that could cause trans problems down the road..
we dont need window tint!!!!! WE GOT MUD YALL!!!!
Bender
Yea, I put in a new pilot bearing.....still kinda stumped with the way its running.
