D60 install questions
Started by Blazin40s, January 19, 2011, 09:46:38 PM
Looks like ill b picking up a one ton front end to go with the 14 bolt ff that's sitting in the garage.  My question is I have a 86 K5 with an 8 lug 10 bolt front and a 14 sf rear.  For now ill b running the drum rears, will I need to upgrade my booster and master cylinder?  Or will stock 1/2 ton stuff work?  I plan on disc conversion in the rear when its warmer out.  Also steering?  Will stock stuff work 4 now untill I do crossover?
Cool, oh yeah forgot to say, its a chevy d60 ill b getting.
you may have to change brake lines
Figured that.  What's the best place to get them?
should bolt right in. and  your half ton break stuff will work.
suport your local parts store.  buy the time you run around trying to save a dollar  you will spend  10.  ==dunno
the local auto parts will have the rubber lines?
Quote from: Blazin40s on January 20, 2011, 02:55:10 AM
Get braided lines...much better pedal feel and less likely to blow one when you have to mash on the brakes to haul that beast to a stop.
mid state bolt and screw will have the 2 bolts you need if you cant find them. for the fourth u-bolt
MUD HUNTER
Earl's Performance braided brake lines... Summit Racing, though I don't think you're going to need to change from you have. Did you look at them yet?
No just got the d60 yesterday too cold too look
Ghetto Fab
did ya get the plates with it too?
Yeah got plates.  But need plates for the ff rear I got
Boggerram87
Dosnt look like my steerings gonna line up. What do u guys use to correct.???? The block?
