mods!!!!!!!!
Started by dfm_13, January 27, 2011, 03:18:12 PM
dfm_13
heres a place to list some cool little mods that they done to there bogger. put anything that you think is cool or that you think has helped you in the mud..... ==suxnopics
moved shock mounts higher on rear axle to keep them out of the mud
dfm_13
there you go keep then comin
Put a transmission in my truck so it would shift lol
dfm_13
dfm_13
heres a quick question. why do ppl hang those thick rubber mats on there front bumper. is it too keep mud off the engine or is it like a dif slide so your dif dosnt dig in? im building my first mudder so im trying to colect some little tips and trick or mods that will make it better. check out my build "s10 build!!!"
MUDFINDER
its to keep the motor cleaner
Middle Road Mud Slinger
dfm_13
alright thx. come on i know you guys have to have some mods......the other jeep forum im on has 50 pages of them lol
well if your other site has that many pages why do you need more input? just saying with that many pages we will just come up with the same stuff you already heard.
The rubber matt is like a cape.  It makes u fly
Quote from: KORNBREAD on January 28, 2011, 04:11:22 AM
im actually curious what others are doing
bigmud44
Quote from: marshall on January 28, 2011, 01:17:57 PM
i always walk pits to see what other people are trying .
#12
Quote from: bigmud44 on January 28, 2011, 01:46:56 PM
x2
when i had the trans rebuilt i had it "reprogramed" to hold gears longer and not slip into gears but "hit" on its shifts i guess ud say. helps out when in the sand dunes
dfm_13
cause the other site is strictly jeep cherokee's and most of the mods are kind of unless i just thought this would be a good place to post any good ideas
Quote from: dfm_13 on January 28, 2011, 02:08:35 PM
oh right on. Just when i read you had 50 pages of tips that why i didnt see the point. but if its all jeep stuff i see why your asking on here then.   ==beer
cnoswalt78
#15
BUILD SLING MUD (wheel speed) ajust tire sizes to fit your trucks wheel spin needs.
And ALWAYS TAKE A BUDDYS TRUCK WITH,
bring a shovel suction kills your tires and axle.
big strap (go way over board)
modifiy your truck with vary stong tow points (to stong is better)
solid 12
I am wraping my headers,  getn an engine oil cooler and depending on time i am puting ladder bars up front and 4 link in the rear
hot rod heep
water proof water proof  water proof
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
Quote from: hot rod heep on January 29, 2011, 07:11:56 AM
Plasticote iginition spray ( basically spray on plastic) its not a thick compound, less than house hold plastic wrap.....i spray all electric connections, dist.
ABlockhd
You can't forget to lock up the axles, at least the rear.  My rear is locked up, and I am going to lock up the front for the next season.  Theres been a couple of times that I think the extra front tire grabbing would have got me out.
