Dana 44 HD ring and pinion
Started by OHEARN.2012, February 14, 2011, 08:24:30 PM
ok so i found out my dana 44 was outta a 77 and then looking at it noticed it was pretty torn up som of the ring teeth were chipped and pinion was worn out and i was wondering where can i get a new ring and pinion . or does it even matter if it chipped can it still be ran?? and how much do the ring and pinions usually run ya? and how do you tell if its reverse rotation or regular?? thanks kyle  GotMud? also it has 4.10 gears
just one more
i think reverse rotation the pinion will be above axle center line, and usually about $150
and i think the reverse rotations came in furds?
sry forgot to add its for a 94 sas so chevy wont do
$150ish for cheaper gears good ones are about $250+ for each axle
well this is going to be my dd weekend wheeler so i dont really need anything high performance
