michigan lift law
Started by danwheeler660, February 23, 2011, 04:14:23 AM
danwheeler660
Hello i just got a 1990 4 door bronco with dana 60 front and rear with 10" of lift sitting on 38.5 15.50 16.My ? is has anyone had anyproblems with the cops here about there lifted trucks on the rd.They say the frame can"t be mor then 24" my is 26" my front bumper is at the 24" but my rear bumper is like 35" off the ground.im in weight category 16 what ever that is..Should i try and trade my tire for 35 15.50 16 my headlights are in the legal range as with my tail lights.  should i just make a add on to my back bumper.to get it and the hight they want.I have been driving the truck for only 4 days now whith no problems from the cops but idon"t want to get stop for haveing this cool big truck.Thanks for any help
.1996 bronco 351 32.11.50 15
my buddy had a problem with this a couple years ago, and it was a 'fix it' ticket, he put smaller tires on and had them re-measure. not sure if that still works, but they are usually looking for junk, not nice lifted rigs
randycrane79
i got hit also just traded tires for the inspection and went back and then put my other tires on after they passed it and havnt had trouble since ya can call over to the lansing secratary of state and get the book for lift laws in michigan
google it....  its been posted on got mud like 10x    click the search button up top.. theres links to the secretary of state...     it goes by vehicle GVWR
danwheeler660
ok thank you i have been to thy secretary of state site and can"t find the weight category i was able to find every thing else i need to find out how much this beast weighs
Quote from: danwheeler660 on February 23, 2011, 04:35:46 AM
inside of the drivers door...    no way its rated over 8600.... my ol 94 f250 was 8600lb      your probably around 6000 or so
i drove my F250 with 38's and 6 inches left  no problem    but its  your call
my uncle drove a excursion on 38's, as long as you dont drive stupid they usually leave you alone.
danwheeler660
 cool thank you everyone,I just went out to read the door sticker and i can"t read it it is to faded
Broncoholic
Bolt on son 2.5 " steel to the bottom of the frame rails. It will keep ya 1/2 within the law.
I was looking at the thing what did ya have to give for it.
Boggerram87
I Had My K5 On A 6" And 37's And The Only Time I Ever Caught Flak For It Was When I Got Pulled Over For Other Things But Never Got Any Tickets For It...Just Warnings
danwheeler660
I traded my 2001 tahoe for it.I was tired of rebuilding the ifs every 3 mounths.So i thought i would be better with the bronco with the dana 60 front and rear
Quote from: Broncoholic on February 23, 2011, 05:27:07 AM
They shouldn't bother you as stated they are looking for junk not nice lifted trucks, my unkles blazer sits on 40in boggers and his frame is 32in from the ground and have had no problums, just don't act like a jackass with it we've been stopped for loud exhaust in it but that's it
millser
i had a 85 chevy 14 inch lift 44s and a 1989 chevy 16inch lift 44s drove them even passet cops if it looks like sh-- they pull you over i build them and deal with it if it happens
4x4fun
I seen that truck in Millford here a few days back, kinda interesting...  ill dig up the lift law rules and post em up for ya.. its all done off GVWR not weight catagory, that i do know...
GotMud?
magic
i typed in mi lift laws on google and found it no problem...yep it's off weight and it tells you everything u need to know...liftlaws.com/michigan_lift_laws.htm
cnoswalt78
The first thing i always do when you get done with project is , fine the nearest state patrol man haven coffie and donuts ask him what you need to fix or if youll even get in trouble. tell him ya just bought it and we wondering. just so you dont get a ticket.
My buddy did it with a 10 second nova on slicks, they said it looked fine just dont go burning your tires allover the place and we wont have a problem!
http://www.michigan.gov/documents/high_rise_vehicle_law_8580_7.pdf
Heres the direct link to the law. I think if your rig looks clean and well-maintained, youll probably be ok. If it looks AFU and unsafe youll get stopped for sure, sooner or later.  ;D
4-play
Had state cop pull me over twice for lift law on my TJ with 35's
They measure in 8 spots, 6 on frame and 2 on bumpers.
I just laughed...I knew I was legal. 24" frame and 26" for bumpers on my jeep.
4x4fun
here's what i found
Sgt. Eric Johnson · Michigan Department of State Police · Special Operations Division · February, 1992
B A B
"HIGH RISE" VEHICLE LAW
Effective March 30, 1992
MCL 257.710c
Motor vehicles fall into one of two categories:
All vehicles must comply with both measurements!
PASSENGER VEHICLES:
Frame Height Bumper Height
12 inches 22 inches
A "passenger vehicle" includes all motor vehicles designed to carry 10 passengers or less, and vans that have a
GVWR of 5000 lbs. or less (most "mini-vans"), except a truck, motorcycle, or multipurpose passenger vehicle.
OTHER VEHICLES: Frame Height Bumper Height
Less than 4,501 pounds GVWR: 24 inches 26 inches
4,501 to 7,500 pounds GVWR: 24 inches 28 inches
7,501 to 10,000 pounds GVWR: 26 inches 30 inches
"Other vehicles" include pickup trucks, full size vans, and "multipurpose passenger vehicles", such as a Blazer, Bronco,
Jeep, etc., or other motor vehicles having a GVWR of 10,000 pounds or less.
ITEMS TO NOTE:
A bumper is now required on both the front and the rear of all passenger cars, pickup trucks, and multipurpose
passenger vehicles.
Frame height is measured to the bottom of the frame at a point midway between the front and rear axles. "Midway"
means the halfway point. This may or may not be the lowest part of the frame. See diagram, measurement "A".
Tires must be inflated to the manufacturer's recommended pressure.
Bumper height is measured at the highest point of the bottom of the bumper. See diagram, measurement "B".
If the bottom of the bumper cannot be identified due to vehicle design, measure from the bottom of the forwardmost or
rearmost portion of the bumper.
If a vehicle has an unaltered bumper that is in compliance with this section, it generally should not be necessary to
crawl under the vehicle to measure the frame height.
The methods in which a vehicle can have a raised or altered suspension is now strictly regulated. All components
must be factory manufactured, and must meet or exceed original manufacturer's specifications. A frame cannot be
added to or altered. All lift blocks must be of single piece construction, and cannot exceed 4 inches in height between
the rear axle and springs, or 3 inches between the body and frame. Refer to section 257.710c(4) of the Michigan
Vehicle Code for a complete list.
Section 257.714a of the Michigan Vehicle Code requires "commercial vehicles", which include pickup trucks, to have
MUDFLAPS unless the vehicle is constructed so as to prevent water and other road surface substances from being
thrown to the rear. Refer to the statute for specific information and exceptions.
hope this helps
GotMud?
