Worst damage U did to a stuck 4x4???
Started by 7387chevynut, February 27, 2011, 02:12:50 AM
Whats the worst damage you've done to your stuck 4x4?
nothing major, broken ball joints, dangling super swamper. brought it to the mounds on a trailer, so i laughed, went home, ate turkey.
'the DON'
broke all axle shafts . front and rear the rear were molly
==wgm
 long day  had two rigs at a feild bogg broke front shaft  then broke 1 rear shaft  so only had a 1 wheel peeler    got hung reving and r to d back and forth over heated the motor and started knocking,
   had the other out and broke the rear shaft , then running on the front end  got stuck then blew that the front drive shaft so we pulled it out then waited about 20 min had about 6=7 guys to push onto trailer and as soon as we touched it the tire fell off broken ball joint  brake line and axel shaft all in 1 day.
midnightmudder
lost rear drive shaft and broke both front axle shaft at same time trying to rock out from a deep spot. my freind who pulled me out 2 miles out in the woods blew a rod pulling me out but we made it back to his house.:(
water pumps seem to be my weak point lol
magic
as we were boggin through some pretty deep p00...the kid riding with me said "ford sucks" and the dam rear tire come flying off it lol
wayne w
danwheeler660
i smoked my clutch and blew both hubs on my old 1996 ranger at silver lake sand dunes when i got stuck.Had to have it towed back to fenton...
.1996 bronco 351 32.11.50 15
When i was about 21 I swamped my DD 2001 4x4 Sonoma, towed it to my buddies house, the K&N cone filter looked like a pancake because it collapsed when the water hit it.  I pulled the plugs rolled the engine over and water poured out of all 6 cylinders.  Dried it out, changed the oil started it up, and almost 2 gallons of water came out of the tailpipe.  3 more oil changes before the oil stopped turning into chocolate milk after 5 minutes.  Drove home and it wouldn't shift out of 1st until 50 mph.  Took it in to the dealer, Throttle positioning sensor was fried, and I blew the rear main seal on the block and the front main on the trans.  The truck was all cleaned up so they didn't say anything about wheeling it and covered it all under warranty, but the bill was over 3K...the truck only had 23,000 miles on it. oops Dumb kids anyways...
because of hummer hole I ripped my rear trailer hitch right off the frame, broke there rear frame section that was mounted to the trailer hitch, got water in the motor,trans and front axle housing, and bent the front bumper down. It was worth it though. None of my friends to this day have even come close to getting as stuck as I was.  It took herb, 2 trucks, and that winch herb had in the back of his truck 1/2 an hour to get me out.
'the DON'
you should have seen the hummer the hole got its name from. it was stuck like that too
Quote from: KORNBREAD on February 27, 2011, 11:28:31 PM
==wgm
Thumper
blew up motor in thumper and in frankenstein, then Kelly severely overheated her truck, pegged the temp gauge, and lost all power and oil press all in the same day, good thing it was at the end of the bogg
THE D&D CREW
i never broke anything but i sank the truck to the frame in the mud and it took 2 tractors to get me out. another time i had hit a hidden edge in 2wd and bent a steering knuckle... couldnt go more than 15mph without the tires squeeling up a storm from bein pigeon toed  ==doh
randycrane79
#15
boken axle shafts and split trans at bellhousing
rangerwheelinmike
cought on fire and burnt up all vac lines
blew both lockouts, got water in the motor, blew the front driveshaft, and blew teh bead on the rear tire
 a=f  not to much here ,,but cindy kay broke the frame on the blazer ,,couldn't fix it ==rant  a=f
countrybogger94
tore the rear end out of our 86 blazer pullin out an old bronco
86 blazer on 38's 355 75 chevy Luv mild 350
