e 85 broken parts
Started by hot rod heep, March 02, 2011, 04:09:05 AM
sweet cant wait to see that bbc in the s-10 it should rip!!!!!!!!!!!!!!
hot rod heep
#21
got my cam and every thing  but the carb and headers
Cam Style  Mechanical roller tappet
Basic Operating RPM Range  3,000-7,000
Intake Duration at 050 inch Lift  248
Exhaust Duration at 050 inch Lift  254
Duration at 050 inch Lift  248 int./254 exh.
Advertised Intake Duration  286
Advertised Exhaust Duration  292
Advertised Duration  286 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio  0.653 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio  0.660 in.
Valve Lift with Factory Rocker Arm Ratio  0.653 int./0.660 exh.
Lobe Separation (degrees)  110
Intake Valve Lash  0.016 in.
Exhaust Valve Lash  0.018 in.
Computer-Controlled Compatible  No
Grind Number  CB XR286 R-10
Valve Springs Required  Yes
Quantity  Sold individually.
Notes  Requires thrust button and wear plate.
that is the cam i went with
je srp pistons
scat crank
sfi flex plite
049 ovel port heads  {gasket mached and the biggest valvs u can put in them }
rpm air gap intack
h beam rods with 7/16s  cap screws
milling oil pump
and 6 cort oil pan
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
solid 12
Hell yea!  Sounds like its going to be a runner!  Whats the compression ratio?
hot rod heep
44 boggers
BBC th400/208
ddmachine
hot rod heep
its never ending   i took my heads in to have the springs checked  and   what do u now    there goes another 275.oo    and new springs locks and retainers      all well  alls i can say  this dam thing beter run good
44 boggers
BBC th400/208
what was wrong with the springs????
roodawakening
PROBLEY SPRING NOT BIG ENOUGHT FOR THAT BIG 660 LIFT CAM  ???
Quote from: roodawakening on April 08, 2011, 02:37:55 PM
if I remember right  the springs should run that big of a cam but I may be wrong.
4x4xdodgeman
spring not for roller cam
hot rod heep
they were like  15 lbs light   and already had some shims under them   and the retainers and locks were not going to work with  the new springs
going to be puting the short block together   this weekend   and probley order the  quick fuel  dp 850  E85  on monday
44 boggers
BBC th400/208
man that sucks~ cant wait to hear it run!
OLD SCHOOL
Quote from: hot rod heep on April 04, 2011, 12:28:56 AM
je srp pistons
scat crank
sfi flex plite
rpm air gap intack
milling oil pump
and 6 cort oil pan
I ran that same cam a few years ago ,worked very well
hot rod heep
geting the new q 850 e85 carb   and my heads back     tomarow  so i shoild be done with the engin shop for a wile  i hope     have got the bild started   will have it runing  soon    cant wate
44 boggers
BBC th400/208
cool cant wait to here a test run
hot rod heep
going on the run stand this weekend for the first start up and break in  then its time to start working on geting the truck ready  for the season   and all together    looking at puting a tilt frount end in it  to make working and tooning  easyer
44 boggers
BBC th400/208
bigmud44
motor does sit way down in the bay IM 6'5 and I had to balance on fender to make adjustments
gunna be a runner time for 44s
hot rod heep
looking for a good set   but  i would like to find a frend that has a set  i could barrow for 1/2 day and see how the truck likes them
Quote from: betterbeaters on April 21, 2011, 03:26:23 PM
44 boggers
BBC th400/208
