5 ton t case
Started by Mudduck, March 07, 2011, 12:02:07 AM
Mudduck
I got t case from 5 ton. Should i use that big n heavy t case or should i take it out and put a lighter divorce t.case ? I ll be running small block for now with 55 inch tractor.tires
Mudduck
==hstrap
'the DON'
i just run my 205 broke only 1 in 15 years
==wgm
bowtieguy
I would run the 205 especialy so you don't have to mess with that air solenoid thing on the 5 ton case
Blow it up then stroke it
blazentrout
I would lose it just do to the wieght.  as far as i know most monster trucks back in the day only ran a 2.5 ton case.
Mudduck
umm... guess i should take that out and either put that aside or scrap em or sell them if someone want it...
Mudduck
==hstrap
blazentrout
if you got a local heavy equipment yard by you, you might get more from them than scrap. what do the yokes look like?
Mudduck
They are flat round type yoke
Mudduck
==hstrap
blazentrout
if you scrap it save the yokes.
Mudduck
Plan on saving the yoke but. T case more likely i ll save it  put em under my bench table for few years then realize i should of scrap it  ha
Mudduck
==hstrap
