how tall is you truck on the trailer ?
Started by woody11769, March 08, 2011, 04:56:27 AM
woody11769
how tall is you truck on the trailer ? anyone know ......and dose anyone know how tall it can be to safely roll down the road .i know some guys tariler there truck with tractor tires and some put rollers on there truck how do you roll??......were just trying to figure out on my buddies truck if he'll be able to put his tractor tires on and still to it down the road at a safe hight ...Thank you for any help
mutt truck
I know that there is a certain width that u are sapposed to be less than, as far as i know... as long as it is like 13' or less u should b fine. But i could be wrong. U can always call dot ( department of transportation ) and find out for sure.
i believe 13'6"   but dont quote me on that!  max of 102" wide
woody11769
would be a pain in the ass for him to have to keep swaping them makes me glad I have a baby truck
you can not be more than 13'6". you do find over pass that less then 13'6".
GLS
#5
A vehicle unloaded or with load shall not exceed a height of 13 feet 6 inches. The owner of a vehicle that collides with a lawfully established bridge or viaduct is liable for all damage and injury resulting from a collision caused by the height of the vehicle, whether the clearance of the bridge or viaduct is posted or not.
http://www.legislature.mi.gov/(S(xwjgpa551szidovrvc2cuc45))/mileg.aspx?page=getObject&objectName=mcl-257-719
The total outside body width of a bus, a trailer coach, a trailer, a semitrailer, a truck camper, or a motor home shall not exceed 102 inches. However, an appurtenance of a trailer coach, a truck camper, or a motor home that extends not more than 6 inches beyond the total outside body width is not a violation of this section.
http://www.legislature.mi.gov/(S(xwjgpa551szidovrvc2cuc45))/mileg.aspx?page=getObject&objectName=mcl-257-717
MICHIGAN VEHICLE CODE (EXCERPT)
Act 300 of 1949
SIZE, WEIGHT AND LOAD
http://www.legislature.mi.gov/(S(xwjgpa551szidovrvc2cuc45))/mileg.aspx?page=getObject&objectName=mcl-300-1949-VI-SIZE-WEIGHT-AND-LOAD
millser
mine sets right around 11'9"to 12'tall on trailer
 a=f no truck,no trailer , a=f
tracker and tow bar  ++peace
woody11769
Quote from: millser on March 08, 2011, 09:43:48 AM
is that with the tire's on it ???
JHHD4by4
I think we sit at  12 feet ...Maybe alittle more...
ROLLIN" DIRTY !!
Mason Muffler & brake Repair, INC.
JHHD4by4
Quote from: 4x4xdodgeman on March 08, 2011, 05:36:19 AM
Yes there is a bridge here in Lansing by the Potter Park Zoo that semi's get caught in(or under,lol) often !! It is 12 I think..
ROLLIN" DIRTY !!
thats a nice park there we drove down just for the park 1 day.  not sure how tall i am this yr not down yet.    about 10' .      ALSO NO WIDE LOADS AFTER DARK OR ON SUNDAYS.
'the DON'
==wgm
ABlockhd
MUD KING
Mine is right around 13', depending on how much mud is on and in it! lol Thats on the small tires. Gotta swap for height and width troubles. 13' 6" is the legal max, but they are right that there are alot of overpasses that are lower in small cities and such. THE BIGGEST PROBLEM IS TREES THOUGH!!!!! There are a lotta a low big branches. I load mine backwards and let the roll bar nock the big stuff outa the way. I would say that if you go much higher than 13' youll be sorry. Most of the bogs are off the kinda roads that have a lot of low trees. Ive smacked a couple low lights too. The yellow stuff in the bed proves it lol. Oh and 102 isn't on all roads, some are 96 max. dont know how strict they are on the 96 though
Where's the BIG hole?
MUD KING
Real variable is the trailer ya got. Mine is a true deckover which rides about 34" tall. If ya got a low trailer with fender cutouts then ya got alot more room to work with
woody11769
Quote from: JHHD4by4 on March 08, 2011, 11:44:43 PM
im sure you can make that roland did with his truck on the trailer he's on 44's around the same hight as your's ......I chickend out
Boggerram87
Welp I'm Gonna Be Eliminating My Trailer Soon.....Gonna Be Able To Load The Truck On The Back Of The Tow Rig...
Truck On Rollers-9'
Deck Height-6"
Trucks Frame Height-3'
So I Should Be Sitting At 12' 6"
On The 16.9's.....13'.05"
Should Be Safe....Might Have To Take The Top Off If I'm Running The 16.9's So My Can Take The Blow Like Grant's...Just In Case Lol
