boxing a frame in
Started by 355REDNECK, March 26, 2011, 06:15:20 PM
355REDNECK
wondering what kind of metal to use
WHEN IN DOUBT THROTTLE OUT
1/8 or 1/4 sheet metal thats what i seen them use on trucks or one of them shows. but i would go with 1/8 inch i think that is all you would need since the frame probably isnt much thicker than that.
i would use 1/4", the 80's chevy pickup frames were about 1/4". 4x8' sheet of 1/4" is $215.
Quote from: marshall on March 26, 2011, 06:22:30 PM
Lot of waste doin it like that, just take some measurements of the parts you want to box in and buy flat 3/16-1/4" stock the correct width and a bit longer than you need. You can ask for scraps in the sizes you need at the steel place and save a few bucks..
Quote from: old school truck dude on March 26, 2011, 07:01:03 PM
i dont agree with that, 'scraps', or drops, are still gonna have to be cut to your size needed, making waste, and they charge more per lb than you would pay for a full sheet. and if you have them cut your material, its not cheap. webber steel, full sheet $215, half sheet $187. bought one last week.
+ acyt and oxy and grindin wheels n labor if your time is worth anything and that sheet is real heavy, adds up.. probably get all the scrap u need at Alro for $50-75 rough guess, idk.. just my opinion..
Quote from: old school truck dude on March 26, 2011, 09:20:42 PM
well, he was asking for opinions, sounds like he has a couple to choose from now, lol
Wild One
An idea.
Find a 2nd frame cheap, put oppisit halves together.
355REDNECK
Quote from: Wild One on March 26, 2011, 11:00:40 PM
An idea.
that could work to
cnoswalt78
A second frame is a good idea, and technicaly all dont have to be boxed bits and pieces uniform all the way would be good, and I would ad crossmembers front and rear to help box tube would work good. just to help keep the frame from flexing any more than it has to! thats how worn rivets and cracked frame happen.
Plus the torches and cut off wheels sucks did it that way a lot not I have a plasma so it's easy todo that stuff now
'the DON'
plasma is the  p00
Quote from: Rescue Rig/Jacked Up Geo on March 27, 2011, 12:03:26 AM
==wgm
i have plasma dreams...some day...
Are you gonna box it completely, or just piece it in between the crossmembers and stuff?
damn_ford
whatever your frame heighth is, 6 inches or 8 inches whatever, you can buy pre cut 8 to 20 foot strips of 1/8 flat from weber steel pretty reasonable.
I did a CJ frame with one 4" tube cut in half, notched it at the bends..
tapped it into place and welded it up.. worked good.
