easyest way to drop a t case?
Started by ShortTemperd, March 29, 2011, 05:50:14 PM
ShortTemperd
need to drop my t case looking for the fastest easyest way to do it any ideas?
just un-bolt it and let it drop. loll
j/k its best to use some sort of jack and a buddy to help guide it down.
ShortTemperd
Quote from: 390JOE on March 29, 2011, 05:58:17 PM
i would but the u joints r frozen to the drive shaft on both sides and i cant get the front driveshaft out with out the rear one out and so im kinda inbetween a rock and a hard spot or in this case a t case between to driveshafts  ==idunno
pry the u joint off the yoke with a  long screw driver ....
ShortTemperd
Quote from: Captn. J on March 29, 2011, 06:07:24 PM
iv tried that this makes me sound like a retard lol but iv tried pretty much everything their is to do
ShortTemperd
dirtydog
Quote from: ShortTemperd on March 29, 2011, 05:50:14 PM
let these guys drive
damn_ford
this is probably the most dangerous and stoopidest thing to do but ill tell ya anyway.
i was trying to get a front driveshaft out of my chevy one time and couldnt. it was froze solid to the flange. i put the bolts back in finger loose and dropped it into gear a couple times. broke right loose! this was in a field, all i had was a wrench and a small hammer.
I'm assuming that you've took the u bolts off the rear yoke. Get something to put in between the u joint and pry it out. May take more than a screwdriver. Or put something in the you can hit it with and you most certainly take the front off without taking the rear off. I've never seen one take more than a pry bar to remove it.
Quote from: damn_ford on March 29, 2011, 06:55:03 PM
wont work if his t-case is broke
how are they stuck? just rusted to the yoke?  never seen that before, but i would assume a pry bar and hammer could fix this, hopefully the truck is big enough to lay under, wouldnt use a prybar on a vehicle supported by jackstands.
LONGER BAR TO PRY With  if that dont work put pressure with a bar and swat it with a  bfh
hot rod heep
if  u have to   sounds like the u joint is junk  get in there and cut the x part withe the cuting torch   if not  the heat  may help  and then pry it smore
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
and make sure you don't have torque applied to the drive shaft... tcase in neutral and/or wheels off the ground..
might be bound up.   just a thought.
Mudduck
x2
Quote from: hot rod heep on March 30, 2011, 01:48:55 AM
good thinking there  safety thought ....
Quote from: Hammerlane on March 30, 2011, 04:22:53 PM
Mudduck
==hstrap
ShortTemperd
the u joints were seized to the driveshaft so i just cut em off thanks guys for the tips-689745
Quote from: Bigdaddy on March 29, 2011, 06:44:57 PM
ya ya !!
