dana 60 help
Started by mutt truck, April 03, 2011, 12:58:04 AM
mutt truck
So i just blew my 60 apart today... the carrier is toast as with missing spiders and the ring and pinion is also junk.
My question is can u take a rear carrier from a 60 and use it in the front axel?
as long as the spider gears are the same spline
d60 fronts have 35 spline for the axles
if the back has the same spline it will work.
if not change the spider gears, if you can
mutt truck
To much power ;D
I am thinkin that it must have been ready to go... i got some pix of it that i will post up tomarrow prolly.
mutt truck
Quote from: Ranger Dave on April 03, 2011, 01:09:03 AM
So as long as the splines match up it can be done???
Do i need to use a reverse rotation ring and pinion as well?
mutt truck
Wow....did it just expolde?? Or did u hit something?
mutt truck
Nope didn't hit nuttin... just exploaded
reverse rotation is for ford or after market houseing.
mutt truck
So if i put the rear carrier in my.front end i don't need a reverse rotation ring gear?
the rear carrier that i m going to get is out of a ford... and its going into a dodge 60.
all the cases are the same.    just spline counts different  rear 60 is 31 spline front 60 is 35 spline
mutt truck
well i am on my way to getting the truck back up and running. It is still going to be a couple of weeks due to money, but i just ordered a dana super 60 carrier with a trac loc posi unit in it from e bay... now just need to get the ring and pinion and then off to the axel guy for set up. It is still going to be a couple of weeks cause i got to save the $ for the rest of the parts, but i just wanted to update Y'all.
why do you have to take it to axel guy? set it up your self.  what gears do you have, or need?
mutt truck
Quote from: 4x4xdodgeman on April 25, 2011, 02:42:54 AM
well i have never set an axel up before, i know the general idea  behind it but its not to bad of a price to have it done. This way it is done right and i do not have to worry about it.
