ezrun brushless
Started by blasterguy911, April 05, 2011, 04:17:28 PM
blasterguy911
are the hobbywing ezrun motors any good you can get esc, motor, and programming card for like $80 shipped to you.
1972 bronco
they rock. I have one its been beat hard. underwate.r in thick mud, sand no issuse really mine make alot of noise but its old and beat  but still has great power! 2 of my buddys also run them and love them. great deal for the $$
what are you putting it on?
blasterguy911
well i have two cars i could run it on right now a old rc10t2 and a little bit newer duratrax evader st but would like to get a slash in the future.
1972 bronco
if you get s 4x4 slash get a vxl then swap in a mamba max pro! I got a 4x4 stampede with a vxl3500 motor and a mamba max pro and its stupid fast!
blasterguy911
wish i could get a mamba max right now but dont have the money right now
1972 bronco
right on ez run will work great for ya!  enjoy it I had my on 3-4 scale trucks(4x4) and a stampede 2wd (very fast, lots of wheelies)
blasterguy911
would this speed control work with this motor
HobbyKing Brushless Car ESC 45A w/ Reverse
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=13445
EZ-RUN Brushless Motor 9T 4300Kv
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=7195
1972 bronco
it should work but I would get the 65amp esc more power and will work better with that motor!
blasterguy911
ok might try to get a better esc this one has some bad reviews and then i could also upgrade motor later on.
1972 bronco
yep I have a 65 amp esc and love it~
blasterguy911
well the more looking into it what would be better for just messing around doing some jumps and takeing it to the sand dunes a 9turn or 13turn?
1972 bronco
13 will have more low end the 9 wont have much but you can gear it to work!
blasterguy911
where did you get your ezrun hobbypartz.com is out of stock its a good price 60 dollors for 9t 35a for now.
1972 bronco
got mine at larrys performace rc
blasterguy911
so i think i found a better setup but thoght i would ask.
60a esc from hobby wing.http://www.nitrorcx.com/3303-2010.html
tacon 3900kv brushless motorhttp://www.nitrorcx.com/96m31-car-2848-3900.html
1972 bronco
my broke ass ford!!
tacon motors are awsome if you have the money here is a cheap setup you can program the esc just like the mamba max it comes with a programer and this set up works sweet http://www.ehobbies.com/dyn3736c.html?utm_source=dyn3736c&utm_medium=shopping%2Bengine&utm_campaign=froogle
JohnDeere Dodge
Lol as long as your not trying to compete with it :-P cheap way to go brushless though.  Tekin or LRP
I have Two things to say about this.
1. HobbyWing systems are what they are. Sometime you get one that last for a long long time and sometime you get junk. They have NO Q.C. at all. I have seen a bunch of these things come threw my works front door.
2. Don't put any brushless system in that Evader unless you put the newer trans gears from the New Evader EXT.  All you are going to do is blow the diff up and strip the idler gear.  Trust me I have done it and sold the car off due to it.
On a side note I would stay away from Exceed RC. I don't know of a single Hobby shop that sells them or the parts for them. They do almost 98% of their business online. I have been told that their custom service is Hit or Miss as well.
IMHO. I would go with a Castle Creations Sidewinder 3 set up with either the 4600kv or 5700kv motor. It's a Waterproof ESC and Brushless Motor. It can handle up to a 3S LiPo. Can plug it into your computer with the Castle Link and Adjust EVERYTHING under the sun with it.  I run the Sidewinder 2 and 3 set ups in all my R/Cs now.
best part is its between $100 and $135 bucks the set up,  I know you can pick up a used one for $50 to $75.
