what do you have to change to run alcohol?
Started by middleroadBOB, April 06, 2011, 09:34:41 PM
middleroadBOB
because of the lower cost of alcohol, i was wonder what do you have to change to run alcohol? just a special carb? is it hard to set up?
carb and filters, expesive new but u can find used setups for decent
You need a pump capable of pushing doble the amount of fuel also. Probably have to redo the seals that come in contact with it yearly also
pump line  carb filter lots of time to tune it and its point less under 12.5to 1 from what I am told
