hydro steering
Started by Captn. J, April 08, 2011, 10:12:45 PM
Quote from: Captn. J on April 26, 2011, 10:12:59 PM
does it matter what stroke i got?  i have 10 inches ... my old one had 10 too  ...
if there is more travel in the cylinder than in the steering  it can break stuff  bif there is no relife valve in your orbit valve but the 4 port ones have it built in on most   the bigger the cylinder the more oil ya have to move to make it work some  orbit valves are made for specific cylinders to work properly   when i seen ya wheell it at bondy it looked like ya hade to turn a lot of turns of the wheel to move it check yer fittings and make shure there not a restriction fitting with a small  inside diameter  that will restrict the flow and make it slow to steer
You want a cylinder match for the psi of the pump too.
it steered just fine before just it now dont want to steer  and i m sure the ram i had was bad or going to be .. i m gonna give this a try n see.
Quote from: BigFrank on April 26, 2011, 11:15:49 PM
The restrictor will look pretty much just like a flat washer, and it will be stuck into a fitting. Like nascar restrictor plates. Also, ppl remove thermostats and put in big flat washers to restrict coolant flow so coolant will stay in radiator long enough to be cooled.
i guess i got everythinfg ready to be mounted on tomorrow or friday   so again i m asking is it okay to use tranny fluid ?   last saturday at a bog someone said to use hydraulic oil  not tranny fluid ... so i wanna make sure . i m okay with tranny fluid if works the same
i need this answered .... to the top then i can go ahead
I used trans fluid is mine. Dex 3 to be exact.
