1984 chevy 1ton dd tow rig
Started by ice87, April 14, 2011, 06:57:25 PM
78man
Jakes Brush Removal
ice87
my truck was put on the back burner but now its time to get to work again. got everything stripped off the frame and almost getting ready to primer and paint after some more rust removal. im glad i took it this far the spring bushng really needed replacing. i picked up everything to put disc brakes on the back also.
Nice ole Chevy!! Looks like your plans are to restore it?
ice87
Quote from: TRENT on October 26, 2012, 02:33:37 PM
Looks like a very nice truck
If your just going to use it as a tow rig/dd then I would keep the dana 44 front. Shouldnt have any problems with it and parts are cheaper to replace when needed. Thats just my 2 cents though
yeah im staying with the 44. since it shouldnt be offroad that often
ice87
Quote from: 7387chevynut on October 26, 2012, 02:36:08 PM
yeah restoring it since i barely any older chevys running around that arent full of rust holes. the 80s body is my favorite of all of them. i just wished that they made a extended cab back then
ice87
any ideas on what paint to use for the frame?
scooterbob
#26
chassis saver... circle auto here in town i used it on mine works great...  i  brushed mine on.. probly look at sprayin it on if u had that option ..the brush takes a long time....
still got some here in a can u want check it out.. its not cheap but  it worked great for me
ice87
Scooterbob I looked at that stuff before but can it handle UV? I know I heard of a good frame paint but it turns gray if exposed to alot of sun.I can't remember the name of it
scooterbob
#28
Quote from: ice87 on October 26, 2012, 05:47:48 PM
 uv rays?? plan on drivin ur truck upside down??? thats bad a$$..lol
uv rays well maby ,,but any brand would after  so much time ... this u can put a top coat on if u wish for more protectant   have to do it when its tacky or after its dry got to skuff it up then u can top coat to protect better  ( i didnt)  or change the color
mines been done a year looks the same... but hasnt been out the garage either. lol...  had buch of that kinda stuff on line and on the can we can look at it this weeken..
this aint the best it works good    id say the" por 15 "is top of line .. if money no option....
ice87
No I don't plan on driving it upside down but I might have to run a body lift so that exposes the bottom of the frame.
Ive always used Rustolium gloss black brush on paint. Couple real thick coats and good to go. Usually holds up for a good 3 years before needing some refreshing.
ice87
Well I'm going to try chassis saver. Almost got the frame ready for paint
freerev
ice87
The frame is going black. Thinking about painting some axle parts silver just to get another color under it
