Rockwell question ?????????
Started by homewrecker john, April 16, 2011, 01:14:28 AM
 To get the axles to track to the same, ive read that you have to flip the hub? Can somebody please explain and give pictures with the explination please. Thanks in advance !!! ++peace
from what im reading on the net, there is many ways to do this mod.  You can machine the spindle to counter sink the wheel studs, you can counter sink the 12 bolts and use taper head bolts and grind a little off the wheel studs, or you can use a Timkin bearing 3926 instead of the 3920 as the 3926 bearing sits .125 out farther.  If you have done this mod, please let me know what you have done, as im curious to see if anybody had problems with the route that they used ???? thanks
ROCK
seen em do it on Extreme 4x4 on tv with 5 tons. not sure if its the same for 2.5 but that episode might be on youtube or something.
Quote from: ROCK on April 16, 2011, 01:46:35 AM
I just looked at the pics of the axles im getting Sunday.....all ready flipped lol
cnoswalt78
Just about anything for 5 tons will work for 2.5 tons. and if you just take it apart youll see what you can do. its pretty easy, there made on the dummy system like all of the armys stuff.
