00 jimmy blower motor
Started by Blazin40s, April 18, 2011, 02:43:28 PM
Anyone changed a blower motor on a 4door 4x4 jimmy 00??
Is it under hood, or under dash?  How much of a pain in the a$$ was it?
camok10
under hood, and to do properly the r&r instructions say the passenger fender must come off but if your good ai wigling parts in and out of places you can do it with out removeing it
84 c10 project
82 c10 beater diesel
No need to take off fender, if it has never been changed before it will be behind a plastic box shaped cover on the passenger firewall, that cover will have a line on it with an arrow pointing to it saying cut here, use a cut off wheel and cut that line and remove box, then it is just a few bolts and it is out. Forget about replacing the cover it is not designed to be re-installed and everything will work without it.
