hydraulic steering pump choice ??
Started by solid 12, April 22, 2011, 09:14:18 PM
solid 12
I am wondering what would be the better way to go with for a pump..right now i have the smaller power steering pump with an external resevior, but i was told i could use an electric pump off of a fork truck..i have never ran hydro steering and know nothing about it so any help would be great!  I plan on buying a 120 amp alternator either way and i was told i would need to run 2 batterys if i go with the electric pump..
Thanks
RaZiN KaNe
i run a stock power steering pump on my hyd set up..... just drilled out the fitting in the pump to allow more flow....never had a problem with it
B.G. Grounds Maintenance
'the DON'
stock pump here with the fork truck orbital valve
==wgm
solid 12
thanks! i will probably run my pump that i got now but didnt know if the electric pump would have been worth the hassel of a 2nd battery and trying to find one
'the DON'
i think mudman runs electric pump. most of us run stock
==wgm
millser
Rollover Herb
==ogm
solid 12
Thanks everyone!  I probably will end up using the pump ive got now
