Extreme 4x4
Started by Disturban, April 24, 2011, 07:21:00 PM
Anyone catch the episode yesterday, he swapped a solid axle in a 90 something blazer and yesterday he gets a reman short block 350 and a Edelbrock kit that comes with cam, heads and intake for a TBI, then he goes on to claim Edelbrock says that motor will make 400hp and 400ft pounds of torque ==roll
I would love to see that on a dyno using his 450cfm TBI that he put back on the motor and stock fuel pump let alone his stock chip. I am emailing them and told him I want to see dyno numbers to back up Edelbrocks Bull p00 claim.
I built a 350 and had a more aggressive cam than that kit, ported, polished heads that was decked and 670cfm tbi with a custom tuned chip and I would put the horsepower between 300 and 350 but no where near 400. Wonder if he knows that the edelbrock manifold tbi bores are only 42mm and the 670cfm bore is 2"/ 50.8mm and he will need to hog it out to take advantage of the 670tbi.
Oh well I am done with TBI and I am not going to teach him what I learned the hard way...now I am into smpfi ==roll
redneck renegade
yea i have no faith in ean from xtreme the bogger he built was a turd
my dad told me bout that episode.... hard to beleive they did it that way.... they claimed that it would cost 1300 bucks to freshen up the bottom end too!!! so they just bought all new for 1500.... that whole motor was like 4k i guess....  ==doh
what happened to jessie?  mmmmmm......jessie
Quote from: marshall on April 24, 2011, 09:50:27 PM
OH YEAH IM WITH YA ON THAT ONE. SHE WAS SMOKING HOT!!!!! 8)  8)
ME OFF
i hear that last i knew she hard back surgery and couldn't do the heavy work anymore and and didn't hear where she went
famous last words
WATCH THIS
i think she is working with chip foose.
hillbilly1975
i also seen that episode and thought the #s didnt add up
All throttle NO bottle. my inner child is a mean little f***er
You can get 400hp out of a TBI motor with that kit but you need the 500 dollar Holley TBI unit for it as well as the Chip. But your also at the about the make of the fuel system.
I have a buddy from High School that put that set up in a Camaro and it was close to 420 HP that they got out of it on the Dyno. But it had the better TBI unit and the Chip.
As for Jessie Combs
She hurt he back during a taping of the show on Spike and could no longer do alot of the stuff on there.  So she left it and then did the stuff on Mythbusters for a wile.
Quote from: Cannaert on April 25, 2011, 11:41:25 AM
The $500 TBI unit is a 670cfm tbi also known as a 454tbi, they are the exact same thing and both flow 670cfm. But you are not going to get any advantage in using it with the stock or even the edelbrock manifold because they both have 42// bores, you need to hog them out in order to use and take advantage of the 670cfm tbi.
A lot of people don't do it and just use a 454tbi spacer so the butterfly's on the 670cfm tbi wont catch on the smaller bores of a 350tbi manifold but then you are not taking advantage of the 670cfm tbi so with the spacer and 454tbi you are still only going to flow as much as 42mm holes will allow and that is 450cfm and that is not enough flow to support 400hp.
This is the whole point I was trying to make, the guy on Extream4x4 says Edelbrock says this package will make 400hp and make it look like it is a bolt on a go package, it is far from that, you need the bigger tbi, you need bigger injectors, you need a better fuel pump, you need to machine the manifold, you need a custom burned chip and with the cam in that package it still will not make 400hp, maybe 325 at best.
email them and tell em you wanna see it on a dyno!
bigmud44
shes on pirate tv perfect woman good looking & she could fix anything ya break
thebig10
coming soon big blown 10....
Quote from: Le Dude on April 27, 2011, 12:06:32 PM
Did it!
JHHD4by4
My husband picks him apart alot too !!  Maybe he is spending to much in front of the camera and  needs to get out there and   go wheelin' !!
ROLLIN" DIRTY !!
Mason Muffler & brake Repair, INC.
I just want his job! lucky dude.
ROCK
seems like every "budget build" they do comes out to 10 grand or more. not a budget build in my opinion.
Quote from: ROCK on May 11, 2011, 03:45:36 AM
