truck wont turn need help (FIXED) THANKS FOR ALL INFO GOT MUDDERS!!!
Started by redneck ohearn, April 25, 2011, 01:51:17 AM
redneck ohearn
they look to be good gunna unhooked steering and take the tires off and move them by hand to see if there good
redneck ohearn
whats the best way to flush the lines and gear box out
i think your sposed to un hook one of the lines and keep adding fluid and just let it drain oout open line
You might try taking the fitting out of the back of the pump. In there is a spring and piston. On the end of the piston is a screen. Make sure you watch how you take it out. Its crucial to put it back the same way(found out the hard way) and make sure the screen it clear.
If you have lock-out hubs, are they locked in or something? And let me ask you this: Will the wheels turn fine when youre sittin stil, but wont turn when youre rollin?
Quote from: redneck ohearn on April 26, 2011, 01:48:07 AM
Take the return hose off at the pump and let it pour into a bucket. Plug the fitting on the pump, keep pourin fluid into the top
redneck ohearn
Quote from: old school truck dude on April 26, 2011, 02:18:50 AM
yes i got lock out and i lock them and unlock them and tryed it and still does the same thing, it does the same thing if im moving or im sitting. it wheel turn a little some in 4 low and me giving it alot gas but once i slow down then it locks up
redneck ohearn
Quote from: old school truck dude on April 26, 2011, 02:33:19 AM
im going to take the pump off and return it then get new one and get a new pressure line hose then flush it and put a new belt on it
hot rod heep
just a idea  could u have a ball joint hanging up  when theres presher on it  and free then the frunt end is off the ground     ???   i have never seen it  but no 1 has said any thing like this    may be worth a look
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
redneck ohearn
idk im gunna do the pump and lines belt and then  go from there
rangerwheelinmike
Quote from: hot rod heep on April 26, 2011, 04:04:54 AM
Very possible!
redneck ohearn
redneck ohearn
Quote from: old school truck dude on April 26, 2011, 12:22:14 PM
Very possible!
if it is how hard are ball joints to replace never done one before
rangerwheelinmike
there hard if u need a hand i can help
the 60 should be a king pin never seen a chevy 60 that was ball joint..
If it has kingpins, might need to pb blast it and work it some to get it freed up. Could be rusted up from muddin and not bein greased, maybe.. Is that at all possible..? And sometimes ya have to work extra hard to make real sure that a fitting is actually takin grease even though it doesnt really seem that important at the time... ;D
redneck ohearn
rangerwheelinmike
