truck wont turn need help (FIXED) THANKS FOR ALL INFO GOT MUDDERS!!!
Started by redneck ohearn, April 25, 2011, 01:51:17 AM
redneck ohearn
i got a 1980 chevy with a dana 60 front with 44, i had to replace gear box on it so i went to cross over steering and got a 2wd gear box hooked it all  up and it wouldnt move no more then a inch then it lock the pump up and the belt just spun so i made sure it was tight and it was then did it again still did it so i got a brand new one put it on and still did it so got a different 4wd gear box and went back to stock steering and it turn a little better but still does it anyone have a answer for this
did you get the lines crossed some how?
redneck ohearn
no hooked them up the same way when took off but it did that when i got the truck soo ill switch them and see tomorrow
Does it do it both ways or only turning one direction? If it only does it turning in one direction your pitman arm is not on center with your gear box.
redneck ohearn
thats it all the gearbox had there own pitman arms on it so i dont think that its funny sometimes it turns both way and then all a sudden ti stops even when im driven it its still hard to turn it
glowworm
if you have a steering stabilzer make sure its not bad.
I got your jeep thing........Now it hurts when I pee
#6
Quote from: redneck ohearn on April 25, 2011, 02:24:26 AM
Pump could be bad as well, have someone turn the wheel back and forth while you have your hand on the pressure line and see if it is getting pressure when it stops turning.
redneck ohearn
no cant be that its a BRAND NEW pump from advance auto but ill try everthing you guys think whats it could be i just ran out out of idea on what it could be
redneck ohearn
Quote from: glowworm on April 25, 2011, 02:35:05 AM
ill check it out tomorrow
dirtydog
is the metal around the rag washer getting snagged on the gear box. just an idea
JeepinJohn
check your u-joints,on your front axles. they might be set up.i went threw this with a truck i had. i put new pump,new steering gear box.and it still did it.pulled the front axles,and found the u- joints,were set up. just something to check,just trying to help ya out.
==ggm
With the front axle on jack stands and truck turned off does it turn back and forth freely?  It should be fairly smooth here, before even worrying about the pump.  If not, take the draglink off pitman arm and make sure gear box isnt binding.  The teeth on worm gear can chip, break and bind easily.  Make sure each knuckle turns back and forth freely too.
have ya checked the fluid level? i know its kinda obvious but it wont work if there aint enough fluid
Raise the front end off the ground, and with the motor off, turn the steering wheel back and forth all the way from lock to lock while you have a buddy watch inside the pump, sounds like it might be full of air. When it stops burping it should be ok, fill it back up with fluid. Otherwise, grease all your fittings real good, and if you find a fitting that wont take grease, that might be where the problem is. Make sure you dont have a kink in one of the hoses. Otherwise, most likely its the steering box. ;D
redneck ohearn
ok i did this right before i had to go to work, i jack the truck up and turn the key so i could turn the wheel and it turn easy so easy i could do it with one finger then started it and move it back and forth a couple of time work like it should lowerd it back down started acting up again
Pump is junk or you got a sticky valve. there may have been crud in the box you put on and it could have jacked it up.
Quote from: MR NASTY on April 25, 2011, 03:19:39 PM
x2 Just because something is new dont mean its good.
redneck ohearn
Ok thank I'll go get a new one and see if that works
cnoswalt78
mine did the same and i drove it forever thast way get musles or put a new pump on it! you got some garbage in one of the ports and it aint gunna come out so replace it.
As Jeepinjohn said also U joints binding will cause all kinds of funky steering issues, I had a thread on here a few years ago about my suburban I thought it was death wobble. When I turned getting on the freeway for example it would be hard and then it would just give and shoot me back and forth almost losing control...very scary p00
