Frame RUST Problems
Started by OHEARN.2012, April 27, 2011, 04:15:27 AM
ok so well lets start i have a 1987 chevy k10 shortbox reg cab 4wd and its my bogger project. but...it has the michigan cancer all over it but today i go out and started tearing into it checking out stuff and i decide ill crawl under the truck and check to see how hard the bed is to take off and i crawl around looking and checkin out frame and stuff and i find well in the part of my frame between the cab and bed i could pul rust off and poke my finger through frame. well i picked this whole truck up for 300 dollars figured id save it from going to scrap. and it was a good start for a bogger. but... this frame  i dont know would you guys run a frame like this or should i just find a better one?? would it be real hard to mae a frame for suin like this from scratch? i just dunno wat to do so someone please help me out confusedd
without seeing it it's kinda a tough call, but ya could add tubeing or square stock to it for a few feet past it, i've seen that a few times
i thought maybe adding 1/4 inch steel inside the frame rails and replacing the crossmembers with tubing
if that frames really rusty dont run it its not safe..  if you can poke holes in it scrap it and get a new one!
Quote from: betterbeaters on April 27, 2011, 01:13:46 PM
junk
k i plan on parting it out and scrapping its not worth me messin with it
Jr
i got a frame for ya ands its a 3/4 ton... even got a clean cab on it!!!
yes has cab alredy found new frame and stepside box clean as hell from the south
So now youre goin with a whole different truck? And youre partin this one out, or what?
yea taking motor trans tcase outta it selling rest
Is the cab worth messin with or is it just rotten?
well check my profect thread its the frogger one. it all depends watcha plan on using it for?
I seen the project thread, cant see the floor too good. Id be wantin it for my K5 frame. Needs a clean title, heat, good glass, and stuff like that. If its just some minor rust repair, no big deal..
floors are solid rockers have michigan rust. heat worked clean title grood glass all round but like i said before im gutting interior but the cab im using i can throw that interior in
There aint much to the interior, is there? just the dash and the door panels? You pullin the headliner out? What do you mean when you say youre guttin it?
i wont go to extremes of headliner but dash gauges all trim and seat or if i could get some decent bucket seets i would use thembut door panels yea im taing
well do u want just cab or whole truck?? 200 for cab
