lift issues again
Started by scooterbob, April 29, 2011, 01:18:01 AM
scooterbob
hey any tricks for gettin front lined up? put lift in and cant seem to get both pins to line up..rhe bottom goes in decent but between the spring and the sway bar  i havin alot of triuble..   any ideas ..thanks
roll axle under truck use ratchet straps to lift it up and keep it level??
2 floor jacks and lift the axle into place.
scooterbob
tried all that cant seem to get sway bar to move far enough to get in place...or well ill say it,,maby its me
did u get drop brakets with kit for sway bar??
scooterbob
dind thik i would need them only went 4 in
well leave sway bar off then put axle under it. if you can then put it on
scooterbob
ill check that out tomarrow..thanks
had that problem with my 60, could only get one bolt started. try turning the wheel a couple times maybe, or ratchet strap it closer. if that dont work take the bolt out of the sway bar, put it together, than maybe the bolt will go in with weight on the axle
