polyethylene seats and 4 point harnesses?
Started by OHEARN.2012, May 02, 2011, 02:10:09 AM
who runs the polyethylene racing seats off like summit and jegs??
are they comfortable good for a long day at the mounds or an all out day of boggin?
wat do they provide over a regular bucket seat?
are these seats only compatable with 4 point or any safety harness?
and wat about 4 points? are they worth it? i now they help to add protection but wat are there advantages over a shoulder belt?
i have poly seats.....keeps ya from sliding side to side.....4 points are good ONLY if you have a cage! NO CAGE NO RACE HARNESSES
bigmud44
#2
I cant imagine sitting in one all day - 5point harness holds YOU where your supposed to be if you have to hold on to steering wheel for support you CANT control vehicle , improper mounting of shoulder belts can do serious damage to your spine
well im not saying like sitting in them all day but is it going to be like sitting on a rock?
and how many different "points" harnesses are there??
you could just use lap belts.....the kind like in the middle back seat of a car.....would hold you in bucket i guess
4 and 5 point are the most common
bigmud44
hour or two woudint be bad with the covers - I would not think of making a pass with out harness on a 5 point is 2 across shoulders 2 across lap + crotch I make my kid wear arm restraints when she runs rail
I use em in my fig 8 cars.  I zip tie a piece of 1" dense foam between the seat cover and seat back, also a piece under your azz.  This helps alot i think.  Ive been upside down before, no cage, no harness! lap belt only!  Your neck will thank you!  Ive ended up with bruises under my arms from banging on the seat sides too.
i knwow the seats are like 40 a piece wat about the 4 points how much they usually run. i know your paying for safety
you can get 5 points for under 40 bucks i think through jegs
I just picked up a 4 point off craigslist for 25 bucks....
ok thats not to bad i was thinking they were gonna be pretty expensive.
have you built roll cages in a 80s chevy before would it be hard or expensive?
Know anyone who drag races or does circle track?   They cant use a harness past the exp date on it.  you can usually get em cheap or even free.  Ive gotten 4 sets free this way.
yea my second cuzin does it ill ask him if he has some.
Quote from: Bowtie972 on May 02, 2011, 02:37:41 AM
3 years from date of manufacture. thats also how i got mine
http://cgi.ebay.com/ebaymotors/NRG-Seat-Belt-4-Point-Safety-Shoulder-Harness-Kit-Black-_W0QQcmdZViewItemQQhashZitem20b7e5d578QQitemZ140524246392QQptZRaceQ5fCarQ5fParts
found these for 50 bucks aint to badid have less than 200 bucks wrapped up in these life savers except for cage. how much ya think a cage would cost for someone to build??
Call wildtime......he built my cage
price depends on how you want it built
well how much was yours and wat do u mean by ways built?
bigmud44
Quote from: OHEARN.2012 on May 02, 2011, 02:46:06 AM
the simplest is 4point hoop behind you with 2down bars going from hoop to floor diaganaly when someone refers to 4-6-8-10 -12 point cage it refers to how many tubes tie into chasis-body
ok john said bout 500 for inside the cab prolly four point cage?
bigmud44
for some models you can get prefabed 10 to 12 point cage for around $ 500 s&w speedway are couple that come to mind
Quote from: OHEARN.2012 on May 02, 2011, 03:08:18 AM
i dont work for wildtime....call him...he is the man with the plan loll
