Rear dana 60 inner bearing help
Started by Eric04, May 16, 2011, 10:09:23 PM
Eric04
Well the bearing was in pretty bad shape so i replaced it..now looks like the only way for it to go back on is using a press.This would require me to pull the whole axle out form under the jeep and taking it to be done.Anyway i can get the inner passenger side bearing onto the spindle without using a press?
Axle is a 75 gmc dana 60
thanks,
Eric
CJ on 42s,1 tons,3/4linked
u may be able to take a torch and heat up bearing itll drop right on ive seen that done many times
warm the housing up with a torch,
but first put the bearing in the freezer for
about 2-3 hours.
small ball peen hammer and a light touch may do it.
bigmud44
Quote from: Hammerlane on May 17, 2011, 02:25:07 PM
about 2-3 hours.                            thats backwards your expanding male shrinking female ???????
