Quick question
Started by mudchik85, May 19, 2011, 12:19:31 AM
mudchik85
I noticed that my rear drive shaft knuckle is bad and I was wondering what would happen if i removed it all together and didnt replace it...any thoughts?
what kinda truck,jeep?  need more info.
mudchik85
Oh sorry haha its an 85 ford bronco
ok so if im reading this right u want to take the whole rear drive shaft out? and drive in front wheel drive?
if it has it needs it... I'm not a ford guy but I would say rebuild it!
jtech
Guys I think he means his CV knuckle that is at the T-case end of shaft . You can take it out but you'll need a longer shaft and some new u-bolt to hold the joint in. Your CV is threaded and the yoke isn't . If this bronco is lifted at all I wouldn't remove the CV it'll bind without one.
mudchik85
Thanks for the answer it is lifted I just wanted to make sure!
