3 x 2 x 1/8 INCH RECTANGLER TUBE
Started by 355REDNECK, May 19, 2011, 09:23:34 PM
355REDNECK
would this be strong enough for a mud truck
WHEN IN DOUBT THROTTLE OUT
Depends on what you planned on useing it for.  If you wanted to build a frame out of it I'd so go a little heavier.
355REDNECK
I would go at least 3/16's thick wall and 2x4 tube.
blazentrout
355REDNECK
bigmud44
#6
both trucks I brought to mid mi are built out of 1 1/2 x 3 .150 wall tubing  8) but ya have to run 10-14 point cage to tie it all together .if you want to run comp bogs a lot of tracks require 75% of oem frame or straight to unlimited class ???
blazentrout
Here is the problem, you need to define the mud truck you want to build. what works for a gutted zuk on toy axles will be diff then a full size crew cab long box sporting 70" tires with 5tons and planets.  I am working on design for a guy for a 'king sling' type truck, the main rails for it are going to be 2x3x.120 with 1.75/.120tube for the cage. so yes it is do able.
