need 1995 dodge dakota help asap...
Started by GRABBER-GREEN MACHINES, June 04, 2011, 03:15:15 AM
i have a 1995 dodge dakota with the 239ci 3.9l v6 ..runs good enough to get me here and there barley..recently replaced the fuel pump spark plugs and wires...and seams to have a low oil pressure when it gets warm ..it putts on take off and is not running smooth...any ideas on what it could be ..and can a 318 carbed fit in it useing the motor mounts allready there..how about a carbed 239 such a thing? and whats the price to rebuild this engine going for these days..
Apprentice gunsmith and custom bike builder..aswell as the fastest lawnmowers and compact 6x6
how did the spark plugs look when you changed them? Have you had to add any oil to it between oil changes? Any type of smoke coming from the tail pipe on start up or take off?
just changed oil like i do every 2400miles and all of it was still in the engine..it does not burn nor leak any oil..no smoke at all..
95 will be a mpfi magnum motor. with it runnin rough it could be a few different things.
1. Throttle Position Sensor
2. Map sensor
3. Fuel Pressure Regulator
if you can give me a little more info i should be able to help you figure it out. like if you leave hard from a stop does it stumble? if your driving does it stumble/run bad? is the check engine light on?
Quote from: Flat_Black on June 04, 2011, 11:20:30 AM
2. Map sensor
yup those were the next steps i was gonna have him follow to. we are here to help ya so just keep following our questions and hopefully you figure it out lol.
check engine light does come on sometimes...when it does stumble it just acks like its misfireing it lags behind when taking off it no longer lags once im at crusing speed untill it give it more gas or i stop...im running a glasspack on it ...could it be no back pressure?....i just dont know how else to explane..it just dont run right ..lol seams to be to be a fue dilivery problem but im not a mech..abut all i can do is change parts and change oil on it..
where abouts in midland are ya? i have to come that way tomorrow and i could maybe take a look at it for ya.
i am by lowes and the mall area but i work from 7-530
