454 flex plate wont line up
Started by rangerwheelinmike, June 05, 2011, 08:54:22 PM
rangerwheelinmike
454 flex plate wont line up with t/c on turbo 400 do we have the worng plate??? Need help
there should be 2 sets of bolt holes on the flex plate, try using the other set yet??
rangerwheelinmike
so i found out that it has a 2500 stall converter could small blocks and big block take a deferent converter? nether set of holes will line up
Quote from: rangerwheelinmike on June 06, 2011, 04:32:55 PM
the balancing is different i believe.
