Chevy Dana 44 Questions
Started by CBakes, July 04, 2011, 07:50:23 PM
CBakes
I am at a point where I am trying to replace all of the axle joints and spindle bearings. My question is, do you need to completely remove the steering knuckle to get the axle shafts out? Thanks for the help.
the harvester
not sure but i dont think so. 8) if its anything like a 60 nope
CBakes
Quote from: the harvester on July 04, 2011, 07:53:11 PM
I've got it tore down to the point of pulling the shaft out and it seems to bind in the steering knuckle...hmm...
7387chevynut
you shouldnt have to remove that knuckle.    Did you remove the C clip from inside the carrier?
chevvv
nope u dont have to  u shd be able pull the axleshafts out just fine through the kunckle opening in middle tight but it will come out
Quote from: 7387chevynut on July 04, 2011, 08:12:49 PM
there s no c clip on my dana 44   they slide in and out
CBakes
Driver side came out good and passenger side was real tight. Eventually came out. Definitely no c clips. Thanks for the info guys. Pulling u-joints out now and gonna have to replace pinion bearings too. Got carrier out. Oh let the fun begin!
Are they under the truck at least?  loll
While u got them out u should throw yer chromo ones from yer 10 bolt in
