cheap rev limiter
Started by blasterguy911, July 08, 2011, 02:20:00 AM
blasterguy911
anybody found a cheap rev limiter that works or know if the msd module for the hei is any good.
1972 bronco
i have a soft touch msd, wires into an hei. it was in a fire and had to clip the plug off, free if you want to try it. takes msd pills
woody11769
i'll let you know in a few days just got one of the MSD moduals to go in a stock type dis. truck wasnt running right enough to try it out as soon as its back to gether i'll let you know....but the way it was to only stand alone one i could find came to a dead end with every other company
msd soft touch rev limiters are bad ass I had one till I got my  6al box
I use the floorpan limiter myself.. works great.
Quote from: Hammerlane on July 08, 2011, 05:07:41 PM
LOL...phil...........that was a good one!!!............and its the CHEAPEST you'll find too!!!!
blasterguy911
Quote from: 7387chevynut on July 08, 2011, 06:44:40 PM
well the cheapest for a little while.
1972 bronco
If you run a 4.3L just use the valve spring rev limiter ==roll
JSvoboda
I used the msd module in a hei distributer and it worked very well. I am happy with it.
I have 2 rev limiters, one on each side of my head. They are 48 years old and dont work as good as they used to. You cant have them, they are permanently mounted.  ;D
I was thinking a 2x4   loll
Quote from: Eroq on July 15, 2011, 01:18:17 AM
wife has one of those.. uses it regularly!
