how much lift for 40 inch tires?
Started by OHEARN.2012, July 15, 2011, 03:20:44 PM
how much lift roughly do i need for 40 inch tires? right now my bogger has 35s on it and they dont come close to rubbing i know it has like a 4-6" inch lift it has blocks in rear but over winter i want to be able to use 40s i know a shackle flip can add bout 6" and then i could use a block to make up for rest and then springs up front but how much do i need?
heres some pix of the truck http://wegotmud.com/forum/index.php?topic=64611.100
Blake Scheuneman
well if you have 35s with good room and say a 5" lift id say a 3 in body lift should make room, 40s only need 2.5 in more body clearence because theyre only 5" taller 2.5 in on to and 2.5 on bottom
chevv ==dew alll
im not messin with body mounts itd be a byTch and screw up lot of stuff
Blake Scheuneman
i didnt say to...the way i explained it was confusing lol
chevv ==dew alll
oo lol its just its an explorer on a 80s chevy frame and theres alot ofwork involved in a bigger body lift
Blake Scheuneman
im sayin suspension lift it...2.5 inches of lift is all you need to clear 5 more inches of tire
chevv ==dew alll
how can i tell how big my suspension lift is? that would be on truck
rangerwheelinmike
i dont think 2.5 will get 40s under it with out rubin
Blake Scheuneman
chevv ==dew alll
Blake Scheuneman
chevv ==dew alll
rangerwheelinmike
well the ranger has 7 and 36s rub lol
yea it has like a 2inch aluminum block idk if theres add a leafs or wat
I bet they would fit like it is!!! trim some off the fenders if ya have to I run 44s with about 6" of lift!
i want to put the fender flares back on it
try getting cut out flares?the more lift spring you put in the rougher it will ride!
i dont think they may cutout flares these sport explorers came with factory flares
i got 40's on my truck with 8 inches of suspension and a lil fender trimming, no issues so far!
i thin i might be able to fit 40s right now i was looing at it and there is alot of room
damn_ford
ive cleared 40s on more than one truck with no lift and a sawzall  ++peace
