Lincoln 3200hd Welder
Started by Brown Cow, July 29, 2011, 09:34:19 AM
Brown Cow
I have a Lincoln 3200hd welder, that I was using yesterday and the wire stopped coming out. But you can pull out the wire with a pair of pliers. Just wondering if anybody knew what could be the problem  was or give me an idea where to start looking and roughly how much it would cost to fix.
Thanks
Randy  GotMud?
wayne w
if the feed motor runs try a new tip and some times the liner will go bad is the wire feed tension set tight enough
Blake Scheuneman
X2 open it up and see iff ur drive wheels are spinning and wires not moving...could be worn or worse could need the motor like he said, what size wire are you using
chevv ==dew alll
Were you welding for a long time?  I had a small Lincoln 100amp that after welding nonstop for too long it would stop wire feeding until it cooled down.  like a thermal overload
Brown Cow
Not really, but I went to check it yesterday. Plugged it in and it was working.
Quote from: Brown Cow on August 01, 2011, 09:28:19 AM
they will also overheat if they are not plugged into a good enough power source.. my neighbors is always shutting off because of the p00 'y wiring in his garage.
