Tranny T-case Help
Started by MadFord, August 02, 2011, 02:35:56 AM
MadFord
I am looking for the best transmission - transfer case combination for my set up. I run in competition bogs in my area that range from 100 to 115ft and 2 to 3.5 ft deep. The truck will be under the knife this winter so I am preparing for the rebuild.
Current Setup:
'79 K10 short bed
Gutted bed, cab, front clip
358ci chevy sb 10.5-1 comp.
sm465 with np205
Dana 44 front and 14 Bolt with 4:10s
39in or 38in boggers
Now I am currently building 408 chevy with 13.0-1 comp, 215cc (2.05-1.60) dart platinum series heads, scat rods, valley and main girdle, full roller assembly, etc. It 'll put me around +-600hp and 600+ tq. So I am dropping quite the coin and don't want to be trying to grab gears. Now hears the question, I have a th350 that I can have rebuilt to my standards and what t-case should follow np205 or 203. Help is appreciated.
forget the 203, they suck, i have one, the 205 is really strong, but another option you should concider is teh np208, it has way better low range
208 all the way 203 is a boat anchor
MadFord
The problem with a 208 is its chain driven and it requires a slip yoke. I have seen a few break in stock powered rigs.
I say  np 241. I run one in my 500 hp truck with 44s and beat the crap out of it works great!
350/205. build the trans strong, and that gear to gear 205 prolly wont break. my 205 has held up, i just break axles now loll
and you can get a Slip Yoke Eliminator for the 208/241 i think
MR. Horsepower
if the motor makes enough power 205 will do you want wheel speed as long as the moter will alow it
MUD HUNTER
NP205 is about as good as they get without getting into big $'s. I've put well over 500 ponies, and 750lbs torque through em' without so much as a hiccup.
85cHeavyMetalBogger
Quote from: betterbeaters on August 02, 2011, 10:58:48 AM
is that a 241c or just 241? was wonderin..
Quote from: MadFord on August 02, 2011, 02:35:56 AM
Current Setup:
'79 K10 short bed
sm465 with np205
Quite honestly...................whats wrong with the SM465 Np205 you already have?????................that stick trans is a hell of alot stronger than any auto trans you could put behind that motor of yours............and you already got the strongest T-case.
The 205 might have a shittty low range  of 1.96.............but your 6.54 1st gear will more than make up for that.
comp bogger=fast. stick cant shift as fast as an auto, auto wont miss shifts either...
Quote from: Le Dude on August 07, 2011, 12:58:50 AM
True..........but there is such a thing as SPEED SHIFTING.........although the SM465 is not close ratio........lol
If you know what youre doin you dont even have to use the clutch once you get rollin loll
another thing we all missed is that if he wants to use teh 205 he has he's gonna need a th400 not a 350, or he'll have to geat another 205
