JEEP HELP - RUNNING HORRIBLE
Started by t_ank5, August 17, 2011, 10:34:17 AM
t_ank5
okay i just purchased a 97 xj with a 4.0 H.O and ran okay but was getting worse as i drove becuase it had almsot year old gas so i took it to auto store. the check engine was on and thru 14 codes. 6 codes were for messed up injectors, multiple miss fires bad coil bad map bad o2 and few other things. well i changed out
map sensor
coil
used cap in better condition
fresh gas with injector cleaner
it runs good in park and then acts like its missing then runs great in park at ideal and when you rev it. then you put it in gear and it run good then sputters and stalls or acts like it missing like crazy.
im pulling my hair out trying to figure it all out cuz its driving me crazy just want it to run good
so i ask you guys what could it be?
bad injectors or clogged injectors?
bad cap and rotor?
bad plugs and wires?
someone help me please
2004 silverado 1500 dd
2001 silverado 2500 HD wt
1996 s10 blazer summer dd/toy
1984 k5 blazer toy
all the codes are comming from one or 2 things. got any code numbers? if it had old gas get some octane boost and run better gas like mid grade or premium. try changing the fuel filter
wayne w
dont know if this will help but mikes ford did the same thing a jeep guy told me his did the same thing it was a fuse that was what it was in mikes truck to good luck
rangerwheelinmike
Quote from: wayne w on August 17, 2011, 01:02:56 PM
x2 with that many codes check all your fuses check wireing if its an auto it could be a slnoide in the trans post all the codes solenoid
t_ank5
Quote from: Flat_Black on August 17, 2011, 12:48:40 PM
i agreee its only a few things causing it  and i did this with the gas already and there is no fuel filter
1984 k5 blazer toy
t_ank5
which fuse was it
1984 k5 blazer toy
wayne w
it was a 15 amp in the power distribution
t_ank5
1984 k5 blazer toy
t_ank5
its not the fuses i checked them all.
the codes that were throwin were
6 bad or stuck open or closed injectors
bad coil
bad map
bad o2
bad wheel speed senor
unplugged trans senor
multiple miss fires
1984 k5 blazer toy
wayne w
dont no where all the fuses in a jeep is but mikes was under the hood sorry couldnt help
sounds like you might have a bad PCM or ECM whatever Jeep uses... maybe swap out the computer for a known good one see what it does...
rangerwheelinmike
you have one problem makeing it have all them codes, check the plug to the trans make sure there clean and check where the wiring harness hook  together. could be the computer but i would check out the trans plugs first.
t_ank5
thanks guys and yes it has to be one main problem.
i can seem to find the unplugged trans senor
now it wont barley start
1984 k5 blazer toy
rangerwheelinmike
it many not be unplugged could just be diry and not makeing contact. or could be someing elce to.
t_ank5
well i checked the trans pluggs all there and plugged in and i wiggled them start it up ran great drove it down the road went to drive it again and chokes out and stalls etc in drive but its good in neutral and reverse
1984 k5 blazer toy
wayne w
sounds like your on the right track clean all plugs or at least unplug and plug in a couple times
t_ank5
1984 k5 blazer toy
my broke ass ford!!
my xj did that and i found a bad fuesable link that powers the injectors i had power on both sides of the link but there was lots of corroison in the wire and was only like 1 or 2 little strands of wire makeing contact i fixed it and ran like a champ
my broke ass ford!!
its passenger side under the hood where all the links are at that i found and when i replaced the one i found more that where getting corroaded (sorry for the bad spelling)
t_ank5
okay ill look into it.
and the plugs on the trans are made in the trans there no actually plugs
1984 k5 blazer toy
