crank and rods ?
Started by dirtydog, September 15, 2011, 11:38:17 PM
dirtydog
can u use a 6" rod on a stock 350 crank and what kinda pistons do u need, will stock compression height work. sbc
I have 6" rods in my 355.. gm forged crank. just gotta order the pistons for the longer rod...  any head will work and you can use the dome, flat top or dish you need ( your heads and cam will tell ya if you need more or less dome)
dirtydog
dirtydog
#3
can u use a 6" rod on a 3.75 stroker crank n what kinda compression height on a piston would u need. what the stock lenght of 350 rods
85cHeavyMetalBogger
Quote from: dirtydog on September 17, 2011, 01:31:12 PM
technically you can, but it is a very very bad idea, with that long of a rod your wrist pin will be right in your ring pack... stock 350 rods are 5.7 inch, and 5.7 rods are the best choice for a 3.75 (400) crank
most guys I know with strokers have 6" rods and more and more guys with 350 are running them now!  6" rods are the way to go, ask any motor guy who builds BIG motors and they will tell ya for rpms go longer rods!!!
Quote from: betterbeaters on September 16, 2011, 01:16:43 AM
Quote from: betterbeaters on September 18, 2011, 03:01:39 PM
id think its the opposite. i think it would be easier to push and pull a shorter lighterweight rod, then a heavier, longer rod? esp at high rpms...
Quote from: Le Dude on September 23, 2011, 11:51:34 AM
I dont know. every motor guys I know wont use anything but 6" rods when buying new they are stronger!
Quote from: betterbeaters on September 23, 2011, 11:57:56 AM
you are right. i researched it a bit, 6 inch rod, the piston doesnt have to move down as far in the bore, AND the piston for a 5.7 rod weighs more then a piston for a 6.0 rod. im guessing to make it stronger.
