axle flip on 02 zr2 blazer
Started by monsteram, September 28, 2011, 01:22:47 AM
monsteram
i wanna do a rear axle flip  heard it gives 5inches of lift in the rear.  how hard is it to do and if i crank up my torsion bars will the truck sit level?
randycrane79
not hard to do at all just flip axel up and change ubolts and no the front torsion bars wont raise ya that high ya have to buy a set of after market clock arms to do that
monsteram
clock arms? never heard of em before   is there a way i can put a block between the leaf spring and the bottom plate or would that not work?
randycrane79
clock arms are the torsion arms they wont go high enough and the rear axel you have to set the spring on top of the axel if you leave the spring under the axel and put a block in it it will lower your truck
randycrane79
#4
heres a place for the rear        Home > Lifted Flip Kits >
 Flipkit Lift 5" Axle FlipkitShip Raw unless upgraded to Powdercoat
Dealers Call for Quantity pricing!
List Price: $154.80
Our Price: $129.00
You save $25.80!
Year: 1982-2005
Make: CHEVROLET
Model: S10,S15,BLAZER,JIMMY
Stock Status:In Stock
Availability:: Ships within 48hrs of payment. We do not charge credit card until it is shipped
Product Code: X4-FLI-CV82XXA
Need help  call 800-842-8789. Before you buy, read Knowledge Base under RESOURCES on Home Page   Axle Flip Kits are used to lift the rear when your original Leafspring is Under the axle.  The best and fastest way to lift the rear.
randycrane79
heres front same place          LiftTorsion Keyways (Pair) Arm-09 With Torsion Bar Only
List Price: $82.80
Our Price: $69.00
You save $13.80!
Year: 1982-2005
Make: CHEVROLET
Product Code: KEY-X-CV82
monsteram
So if I get both those ill be all good? How do I check the pinion angle is right
u wont be just good ... u will have pinion angle issues. maybe other stuff  maybe brake lines and etc  small stuff u re forgetting
randycrane79
yes thats just to get the lift that aint all there is to it
lots of little things that bite the ass
monsteram
ok  u guys recommend a shop to do it so its done right?
randycrane79
if ya never done it  and not sure ya can do it then yes dont get in over ya head not a good place to be
it s not hard to do ... shop re costly in long run unless u have a deep pocket
monsteram
right  id honestly rather spend more money and have it all done right since i've never done it before  esp when it comes to pinion angles etc  don't wanna be the guy who thinks he knows it all and it done completely wrong lol
Mudduck
As for rear i wouldnt worry about pinion angle cuz u.can set ur angle before u weld up ur perch to the axle tube but for the front i have no idea i dont deal w ifs
Mudduck
==hstrap
best to do a sas on it....but if u stay ifs, u need to buy a good name lift kit.   Id say if u wanna go cheep do a 3inch body lift and you can run 33s.  Anything bigger and you will need to buy stock in cv shaft company.
Didn't u just spend tons of money on a ram???  What happened to that truck?
monsteram
unlimited off road messed up  when the put new driveshaft in i kept snapping u joints, never fixed my tray  they charged me 6 times for pullin and bolt it back up  i paid for 5.13 gears and they put 4.10 gears in it   just kept haven to put a p00 ton of money in it just to drive it and it gt to be to much so
Start wheelin and daily driving the blazer and you will encounter the same problems.....leave it stock get some good mud tires and give her hell
Quote from: Blazin40s on September 28, 2011, 02:58:07 PM
second that!
My wifes truck is a bone stock 4door blazer that I syuffed 31 mud tires under.  Its a blast trail riding it, it does good and dosnt break.
