Good GM Wiring diagram
Started by Cannaert, October 06, 2011, 07:59:31 PM
I need a charging system wiring diagram so I can re wiring my Jeep.
Its  a one wire Alt and I am having no luck in finding a good diagram online or in ym books to go off of.  It pissing me off.
I just getting pissed off due to the fact all I am fining is some dumb GM/ Ford or Dodge Hybrid crap with external Voltage regulators and what not.  This one of my big hold ups right now on my Jeep besides me having the lack of me being able to weld well enough.
Ok this is too easy. If it only has 1 terminal and no plug-in spot then hook a fat wire straight to the battery. If it has a 2-prong connector also, then the inboard (with the alternator mounted on the engine) prong you simply hook it to the same terminal as the fat wire. One of those yellow crimp terminals will slide on it, short piece of wire and a ring terminal on the other end..  Itll work like that. You can even put a switch in the circuit to shut it off for competition.
Im postin frm the fon. You can also take your test light and find the wire that is energized when the key is in the run position and hook it to said prong on alt instead of above way. big terminal goes direct pos batt post always.
x2 on that, have had to re wire a few because of mice.....
