no heat!!!
Started by scooterbob, October 18, 2011, 11:01:21 PM
scooterbob
so long story short changed heater core because it was fogging my window..had a good leak..
now i have no heat,,before took it out had awsome heat now i have noone?
what did i do?
yepp fartt the system :) prolly got a air bubble in the system
scooterbob
how exactly do i do that ?? i had the ratiator cap off few times looks like a cyclone of water in there
randycrane79
is it blowing air in vents? cold ..warm...?
scooterbob
luke warm at idle
going to reroute the hose from off the radiator to the water pump and plug the ratiator
95-Jeep
what kind of vehicle? some of them had bleeders in the coolant system
randycrane79
pos stuck thermostat or a messed up trap door
scooterbob
Quote from: randycrane79 on October 19, 2011, 02:36:04 AM
thought bout the thermoste but worked good hour before changed core
but good thinkin on the trap door did have some words with the linkage when was in there have to check that out ....thanks
scooterbob
Quote from: 95-Jeep on October 19, 2011, 02:30:57 AM
85 k5.....kinda
randycrane79
very poss on the trap door then if it aint just rite it prob stuck
scooterbob
never crossed my mind, had me baffled cause the lines seemed warm
randycrane79
how long did it run  to get warm?
scooterbob
 yeah let it run 15. 20  min before left work  its was luke wrm when  took off and went to a chill
randycrane79
sounds like a trap door  but even more ya got air in system  if it was trap door it wouldnt change heat just stay the same so im guessing air  the way i do it is fill it up start it up run it till warm then have someone jump in it for ya and rev it up a little bit poss 2gs and then fill it up some more and put cap back on and then have them let off gas and it should take
randycrane79
i have seen thermostats do the same thing to even thou it was good if filling it up dont get it i think i would do thermostat
if it was me
scooterbob
goin to tinker with it on lunch.. did the rev up theroy and fill before i left shop after was warm..takin the hose off ratiator and back fill core?
That's gonna cause more air in the system, them ol chevys are a pain to bleed out sometimes
scooterbob
changed thermostat think it stuck open... find out in the mornin
randycrane79
that would do it for sure
