gear ratio
Started by 355REDNECK, October 27, 2011, 07:51:23 PM
355REDNECK
what is considered high and what is low
WHEN IN DOUBT THROTTLE OUT
3:08   is high      and 6:72 is low               like in your t case     1.8 high  to 2.6 low gear
355REDNECK
which one is better high or low gear
depends on the application, mileage high is better, power low is better
355REDNECK
what whould be the best gear ratio for a mud truck. for tire speed
85cHeavyMetalBogger
depends on tire size and h.p.
Quote from: 85cHeavyMetalBogger on October 28, 2011, 07:57:04 PM
x2 with 500 hp and 44s I run 4.56s in low range on my 241...... if I remember right I have about 47mph wheel speed at about 7000 in 2nd gear.... and its not enough!
ballistics-10
I am going to run 513s with 44s but with a 208 and 700+ bbc
85cHeavyMetalBogger
Quote from: bigmike on October 28, 2011, 09:24:23 PM
sweet, what size axles? t case will prbly let go..
ballistics-10
60 front 14 bolt rear and yea it might let go we will see..
Also depends on axles.  14ff lowest gear is 5.38.
38s  on 1tons with 5:38s 400 trans/dana 300 t-case 400 + hp sbc hope it works for me
