fuel injected
Started by 355REDNECK, December 08, 2011, 01:59:57 AM
355REDNECK
what are you thoughts on it in the mud. like on rails
WHEN IN DOUBT THROTTLE OUT
Its the way to go. No farting around with a carb.
bigmud44
on gas not worth the trouble on alcohol better be good tuner
355REDNECK
Quote from: bigmud44 on December 08, 2011, 02:10:02 AM
thaat what if thinking alky
ToughBowtieTruck
Next carb problem I have with the 77 it's getting a standalone Holley TBI system. Carbs are an easy way to make power, but it's so dated these days.
bigmud44
I should rephrase stock or slightly modified cant beat it when you said rail just assumed 1000 + hp
its the p00 if you know how to use it!
becomes very effective in off camber situations where carbs run out of fuel
355REDNECK
were would i buy a top end for a small block. intake and hat
Quote from: Hammerlane on December 08, 2011, 05:22:47 PM
Fuel injection rules... carbs are easy but FI makes more power and doesnt run like p00 when you are bouncing around n going up hills
355REDNECK
and plus great throttle response
7387chevynut
Quote from: lilred on December 08, 2011, 08:14:50 PM
So that 350 in the S10 of yours is EFI?
chevvv
355REDNECK
what is better electronic or mecanical
ToughBowtieTruck
Quote from: 355REDNECK on December 11, 2011, 06:44:03 AM
Electronic by far, it can adapt its settings to stay running smooth in real time. Mechanical just does what it's preset to do. Same goes for diesel engines.
73chevytruck
Switched my 91 chevy to fuel injection because it was carb when I got it and I love it. Thinking about possibly making my bogger fuel injetion to at some point
Quote from: 7387chevynut on December 08, 2011, 08:58:01 PM
TBI yes
