Project Redo Rockwell/ Mean Streak / update 8/24
Started by Bowtie972, December 26, 2011, 08:03:29 PM
Got some plans for some body work and new sheet metal, and maybe a different color???  Trying to decide.
Rumor Has it!
Bowtie Or Die..
989F150904
blasterguy911
1972 bronco
cat150
Quote from: Gearz on February 21, 2012, 05:02:13 PM
  woho ==djdj ==roxx Tim your one hell of a great gear head with wrenches and fab work. Hats off to you Great Job!!  chevvv
x2
lookin great!
'the DON'
==wgm
middleroadBOB
Quote from: middleroadBOB on February 23, 2012, 12:32:38 AM
who did you get your pinion breaks from?
I got my brake from DIY4X. Came w/ brackets, rotor and bolts. You buy your own reg Chevy truck caliper and pads.  I did have to shim my bracket out 1/8" so the caliper would fit right om the rotor, Other than that it works good.
Quote from: TRENT on February 23, 2012, 02:54:04 AM
I see ya made another heavy duty driveshaft loop, haha applaudd
Oh yea. This ones quite a bit thicker than the last one. Hopefully I never need it. Lol
Quote from: four_by_ken on February 23, 2012, 03:16:30 AM
Very nice.
Looks like room for bigger tires too.  :-)
I wouldn't mind picking up a set of tractors to use once in a while.  I won't sell my 44's though, I'll run those most of the time.
FilthyMoney
Quote from: OHEARN.2012 on January 25, 2012, 04:01:05 PM
Quote from: Bowtie972 on January 21, 2012, 07:44:53 PM
A few more pics
that for axle wrap?
I keep reading about this "axle wrap" but I'm confused as to what that means?  I'm looking to go 2.5s in the near future and all the pointers that I can get will help.
Quote from: FilthyMoney on February 23, 2012, 03:59:56 PM
A few more pics
that for axle wrap?
i kinda know what it means but when you have somewhat of a high horse motor and ur sitting there and you lay into the throttle youll get axle wrap which means the axle housing itselfs is twisting before the tires actually turn and if u have big blocks etc the amount of axle wrap is multiplied
FilthyMoney
Can you avoid this by strengthing the housing or adding some sort of link bars? Or is this just a fact of rocks in general? Are there any fixes?
Axle wrap primarily happenes with leif spring applications when under load the axle twists breaking ubolts driveshafts and in most cases cracking of the t case, ways to eliminate axle wrap are ladder bars or a simple link likw what you see with this build, 4 link is by far the best way to eliminate axle wrap, its also the best way to maintain your pinion angle through out your suspensions full movement
FilthyMoney
Quote from: erikmud on February 23, 2012, 04:52:23 PM
Thats what i was thinking. Thanks guys, sorry for jacking your thread! Great build
