"THE HANGOVER"
Started by solid 12, December 29, 2011, 07:58:35 PM
solid 12
this is going to be my permenant bogger  ;D i put my 1 tons with 5.13's and 44" boggers..got alot of work to do..i need to move the spring mounts back since the lift spring i got were too long and pushed my shackles back to where they are horizontal right now!  thats why the front tires are not center right now..then i need to get some coil springs for the rear to level it out
solid 12
another pic
chico
flip the springs around. they look like they are in backwards.
looks great do we still get to drive it to the boggs? lol
Quote from: Flat_Black on December 29, 2011, 09:49:32 PM
put one in backwards before myself, whoops
redneck ohearn
thats sweet!!! how much lift ya got on that?
355REDNECK
WHEN IN DOUBT THROTTLE OUT
solid 12
thats what my dad said too, but we measured the old springs and they were 45" eye to eye and the new ones are 51" eye to eye and they measured the same from center to eye..everything was good till we put wieght on the suspension..once we did that the rear shackles went from being vertical to being horizontal!
solid 12
Quote from: betterbeaters on December 29, 2011, 11:04:26 PM
thanks alex!  depends on which motor is in it..if i still have the vortec in it then yes, if my big motor is in it then only if i have some sort of exhaust
Quote from: redneck ohearn on December 30, 2011, 01:40:47 AM
thanks! if the front springs are 10" then i have 18" of total lift..i was told they were but wasnt 100% sure what they were
thanks everyone else for there comments!!
Stump Jumper
solid 12
i forgot to mention it will be going on a diet too!  plus i just got my coil springs tonight thanks to Topfist!!  thanks again tom!
Quote from: solid 12 on December 30, 2011, 03:49:41 AM
measure from eye to center pin. the wrap on the eye from what i can see goes down that should be the rear. just trying to help.
solid 12
Ok, thank you! I hope your right!  That would make for alot less work :)
STEUERDUKES
DRIVE FAST & TAKE CHANCES!
kEEP THE RUBBER SIDE DOWN!
solid 12
muddnoob
