Never E-Nuff update 3-2-2025
Started by Gearz, January 02, 2012, 06:41:43 PM
Gearz
#20
Quote from: Bowtie972 on February 24, 2012, 04:20:12 PM
Holy  p00!  Thats Heavy Duty!  Nice Hauler!    applaudd
Orange Crush said go big or go home to me other night. ==jk  Think I did good. Have to have room for power washer,water tank,more tires extra parts for long trips maybe even a camper mounted to trailer to stay in. Ideas are running wild threw my head right now  ==idunno
stickler42069
good to see this finally coming along been a while since i sold them axles  ==kp
Rollover Herb
==ogm
Gearz
#25
 ==thanks All!
Well been working on it a little. Got front clip back on, raidator mounted, large trans cooler mounted ,engine chain down,battery mounted, front bump stops in, cross brace over rear drive shaft notched an remounted, front drive shaft took out to upgrade to 1410 joints an got rid of double vilosity joint. mounted trans temp gage. ready for fuel if it only had a front end under it.  :( Took it out, striped it to just a housing. Haveing housing milled an fab up mount to fix the two stud problem I had. O-so close  ==wgm
Slick
Were #1 <---- Click & See!
Gearz
#27
Quote from: TRENT on March 04, 2012, 03:28:07 AM
holy wtf did you have goin on with your front axle man
and whats the chain for? limit engine movement ???
Axle had outers cut off - turned center section to limit some drive shaft angle - outers welded back on - shim welded on spring plate too fix sping angle - witch leaves the two studs at the wrong angle - this is how I got axle - if you see in pic they bolted square stock to axle at wrong angle and fixed by bending square stock in rear adding threaded rod- - front treaded rod in axle front stud hole - locked down square stock with nut - then bent threaded rod too fix wrong angle. This my have worked for them but I know it has been bugging me sence I got axle. I new I had to do something an never adressed it till now.  ==hmmm  will be strong when it comes back from its surgery
Chain -- is to do just that help limit engine movement chained both sides - headers are  really close on passanger side down by frame. Just figuered this would help things  Or crack my head  ==idunno I  love all  input. Let me have it guys good or bad idea on chain ?
I dont see anything wrong with the chain.   I have one on mine, with no problems.  Mine has just a tiny bit of slack to allow a little flex.  Some GM cars came factory in the 60's with a limiting cable on the motor. My 67 Impala did.
looks good idea on the chains  ya dont realize how much the rubber mounts let stuff  move around
the chains are fine and will work great I know a few people who do that with no issues
This is one nice truck I seen it today and one hellova garage! Nice meetin you!
i leave the chain tight in mine, no problems.  LETS BOG IT !!!!
Quote from: burl on March 04, 2012, 11:37:40 PM
yeh nice garage BIG MONEY...lol
Gearz
#34
;D  ==thanks great to meet you put face with name. .
Quote from: Orangecrush on March 05, 2012, 01:37:52 AM
Lots of hard work ! ==thanks ==beavis Know problem going to my dog house or man cave   I,am seeing a party in real near future. Theres a virgin truck that needs to be baptized out back. Drinks on me  ==dancinbananaa  ==sm ==band monkeyy
Quote from: Gearz on March 05, 2012, 03:14:39 AM
Lots of hard work ! ==thanks ==beavis Know problem going to my dog house or man cave Never E-Nuff  sorryy Love to party live it like its your last day everyday. I,am seeing a party in real near future. Theres a virgin truck that needs to be baptized out back. Drinks on me  ==dancinbananaa  ==sm ==band monkeyy
Im waiting for the invitation,lol
I'm trying to hurry up the body work on mine so I can bring it too.  Mines kinda a virgin again.    loll
Gearz
#37
More than welcome Tim to bring that virgin . No date set yet will do soon as front axle comes back. Working on closing engine compartment off from front fenders with belting. shift rod , set fuel pressure----- drop the hammers an wrenches lets go find the MUD!!! and its going to be 60 deg. too day  yeahh
Gearz
Well poured fuel  in fuel cell the other night. Only had one very small drip from a fuel filter. Got new one on the way. Fired engine up tonight. O such a sweet sound BBC. Still have to pull distr-cap to put new msd rev limiter cap on. Dam was it nice to hear it run. Love the new electric fuel pump ,new carb. fired engine with first turn of the key. Still have to set timing. replace drain plug seal on transmission pan its got slow drip.
Sweet!!!! ive been watching your build forever im glad to hear its almost ready to tear up the mud  yeahh ==rocks
