first bbc build
Started by scary10, January 10, 2012, 02:56:08 AM
scary10
first bbc build, shooting for 500 hp 500 tq  with red around 6000, need to know a good solid tapet cam to run ,heres what i have now for parts,std bore 454 4 bolt short block ,119cc 781 oval port head 50cc dome pistons should be around 12 .5:1 comp,going to run duel plane intake  what would be a good cam for this, puting it in my cj rockwells with 672 gears
i usually just randomly pick one from the bottom part of the list, so you wouldnt want my help
4x4xdodgeman
that dose not make sence to run that much comp and only run it at 6000 rpm. bone stock big block turns that. must people i know turn all there big blocks at 7000rpm all day long.
My MSD is set at 6000, just cuz ya can doesnt always mean ya should. And its a forged bottom end, it would prolly hit 7500 easy
Quote from: J.C. on January 13, 2012, 01:15:30 AM
if it makes peak power at 7500 (just saying) your not even getting close to what it really has. mine peaks hp at 7000 turn it to 7500+ all day. why? it sounds better! lol
as for what cam you should i use call a machine shop or a cam comp.. and ask for ideas or tips using the info on parts you have.
Quote from: betterbeaters on January 13, 2012, 01:21:40 AM
i know ;D, i cant shift it fast enough now loll its a pretty gnarly ride at 6000.
mutt truck
Quote from: 4x4xdodgeman on January 13, 2012, 12:07:50 AM
Most big blocks as stock shouldnt turn more than 4500 rpms. They are kniwn for tourqe not high r,s
my buick bb is reved at 5500. I was told it will run 7500 easy, all forged and studded lower end.
I agree with the previously stated... call a machine shoo or a cam company for ideas...
Tell them ur specs and what u are looking to get out of it and they will probabky be your best bet!
BAD APPLE
Had a stock big block in my truck for a couple play days after I blew up my good engine it turned close to 6 so they can rpm high at stock form just not good for them its easy to over rev a stock big block
no rest for the wicked
scary10
well i bought a book to day max performace bbc on a budet,  well have see what mr vizard has to say, my 383 is engine 9 out of his sbc book basicly and rips but its been bored&crank turned to there max been beat it for 6 year ,freshen it up every winter the bbc is my back up plan if the 383 pukes in the middle of mudden season . all my freind say build a bbc
mutt truck
I was always a small block fan till i got my firat big block for my new build. It was a 455 olds all stock with a sthal and some gears and i tell u what... i liked it a lot. Now i got a 455 buick that is built up a bit and it make some power. But i still only turn it at 5500 and it does sweet... big bkocks got tourq!
